FXiA4 and FXiA6 as rear and side question
helipilotdoug
helipilotdoug Posts: 1,230
edited January 2010 in Speakers
OK, I just picked up a pair of A6 and A4 FXi's to use as side and rear speakers in a 7.1 system. Need suggestions on which set to use for rears. My thinking is to use the A6's for rears, but wondered if others have used this setup, and have some advice. Also which should be used for each position, Bipole or Dipole? Thanks!
System is:
Receiver: Pioneer VSX-84 TXSi
Mains: Good old SDA 2's Bought new in the 80's
Center: CSi A6
SW: DSW MicroPro 1000
Side: ?
Rear: ?
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
Post edited by helipilotdoug on
