FXiA4 and FXiA6 as rear and side question
helipilotdoug
OK, I just picked up a pair of A6 and A4 FXi's to use as side and rear speakers in a 7.1 system. Need suggestions on which set to use for rears. My thinking is to use the A6's for rears, but wondered if others have used this setup, and have some advice. Also which should be used for each position, Bipole or Dipole? Thanks!
System is:
Receiver: Pioneer VSX-84 TXSi
Mains: Good old SDA 2's Bought new in the 80's
Center: CSi A6
SW: DSW MicroPro 1000
Side: ?
Rear: ?
System is:
Center: CSi A6
Side: ?
Rear: ?
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
Post edited by helipilotdoug on
Will be interested in following your thread. I am looking for rears for my RTi soundstage. How big is your room.
Room is about 14X14, fireplace in front left corner, kitchen to rear with bar, and open into small dining room back left. Hallway at 45 deg. angle exits on right rear.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Bumpity Bump Bump! Anyone???Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
Helipilotdoug,
Does not look there are many FXi users out there. Wish you had a 37' long room so you could give me input on how your FXi speakers are working out. If you get a minute, check out my post and see if you have any suggestions. Thanks,
