Will these amp plans work?
Red777
Hi all: New here, have another thread started and need to move forward with this amp. Sony TA-N9000ES, It came today from Saturday Audio in Chicago, under 400, in two days to bumsquirrel pa.It is heavy-packaged well. Anyhow
I digress-I want to keep 7.1 if possible (and needed). Can I pick and choose which channels are being driven from the amp or avr...ie run the f/r from the amp-center from the amp-rs from the amp and rr from the avr? Does actually connecting the pre-out cancel sound from the AVR? And will it pass through that 7.1 anal. in from my blu ray player to my avr and then to the amp. Or do I bypass the avr and go straight to the amp since the player is decoding the dts master?
Thanks for any input I appreciate it. I know many of you are well WELL beyond my situation. But I thank you for any advice. I have been searching the forum posts alot. What a wealth of information.
55 Samsung 7100
Pioneer 1017vsx
Pioneer 51fd BluRay
Sony TAN9000es Amp.
Polk RTI8
Polk CSI3
Polk FXI6
Polk RTI4
Velodyne dps10
xbox 360
AR xsight remote
Pioneer 1017vsx
Pioneer 51fd BluRay
Sony TAN9000es Amp.
Polk RTI8
Polk CSI3
Polk FXI6
Polk RTI4
Velodyne dps10
xbox 360
AR xsight remote
Post edited by Red777 on
What receiver are you trying to use and I will look at the manual for it. It is possible when you select the pre amp function it cuts out the amplifier section. If you can utilize the some of the receiver amps you might consider a BTL set up on the Amp.
Pre amp Adcom 870 HD
Front Amps Adcom Gfa 8500 and Gfa 555II bi-amped
Surround and center amps Adcom Gfa 2535, Gfa 5400
Denon DVD-A1UDCI reference DVD
Line conditioning 3 each Panamax M-5400-PM's with 30 amp supply
Polk RTi's
Velodine and M & K subs
Audio Quest cables
Starcase rack -
My receiver is a pioneer 1017vsx. It has the 7.1 preouts-I do not recall a setting in the menu related to this.55 Samsung 7100
Pioneer 1017vsx
Pioneer 51fd BluRay
Sony TAN9000es Amp.
Polk RTI8
Polk CSI3
Polk FXI6
Polk RTI4
Velodyne dps10
xbox 360
AR xsight remote
