Loud Music Sounds Harsh
2
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    Mostly Mp3's that get really harsh
    TV- Samsung 24" LCD T240HD
    5.1 Receiver - Harman/Kardon AVR 247
    Stereo Receiver - Harman/Kardon 3390
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Sub - SVS PB10-NSD :D
    Playstation 3
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2010
    The fact that it's getting harsh is a good indicator.
    Main Surround -
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited January 2010
    I have your set-up (a pair of Monitor 60's and a HK 3390) in my bedroom. I listen to music fairly loud at times and I can tell you with utmost certainity that -10 is WAY TOO LOUD. Regardless of source, it's probably going to sound a bit harsh.
  • tderks
    tderks Posts: 13
    edited January 2010
    Add up the total load of your system. Make sure you consider the Ohm load on your receiver or amps, this greatly changes the power requirements. Most houses use 15 amp circuits using 16 GA wire, that’s 1800 watts or 1800VA volts x amps. If you’re getting up to that or above your circuit rating, it’s a sure bet your dropping voltage and starving your amps. Furthermore line conditioners also reduce the amount of power available.
    Pre amp Adcom 870 HD
    Front Amps Adcom Gfa 8500 and Gfa 555II bi-amped
    Surround and center amps Adcom Gfa 2535, Gfa 5400
    Denon DVD-A1UDCI reference DVD
    Line conditioning 3 each Panamax M-5400-PM's with 30 amp supply
    Polk RTi's
    Velodine and M & K subs
    Audio Quest cables
    Starcase rack
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    ShinAce wrote: »
    +1
    Why didn't you just say that to begin with, instead of laying all the blame on mp3s?
    Seriously, turn it down before you blow the tweeters and try a few different recordings to see for yourself if it's the music or the speakers.
    Well, it's both, really....
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    So having it hooked up to a power strip is bad ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • tderks
    tderks Posts: 13
    edited January 2010
    It could be, give a list of equipment what is the draw on the outlet.
    Polk RTi's
    Audio Quest cables
    Starcase rack
  • tderks
    tderks Posts: 13
    edited January 2010
    If the sound changes and from loud to really loud, you are probably driving something to hard. If you starve an amp for power it clips early due to the voltage drop. Distortion and amp clipping will kill the best speaker faster than over current. I run 450 watts per channel on my fronts and they sound the same no matter what listening level. The MP3 as stated in this thread early, garbage in garbage out. The power strip well, I don’t know what it is, the rating or the wire size is to the outlet. I would suggest a good power conditioner from Furman, Panamax, or PS Audio. To give you a clue, for my hungry amps I ran a separate 30 amp AC circuit from my breaker panel and the use the normal 15 amp outlet all on the same AC Leg (same phase), with three 15 amp conditioners.
    T
    Polk RTi's
    Audio Quest cables
    Starcase rack
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    What is exactly does a power conditioner do ? Make sure the receiver gets the power it need ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    F1nut Posts: 51,750
    edited January 2010
    Bottom line, you are asking way too much from an 80wpc AVR or stereo receiver. MP3's aren't helping matters, but you need to realize the limits of your gear and either resign yourself to the fact that you can't turn it up as loud as you would like or that you need to get a nice power amp.
    Here's a tip.....audio isn't about how loud you can get it, it's about how good you can make it sound.
    With the gear he's running, he's not even close to the limits of a 15 amp supply.
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    Ya i was just testing the power increase from the HT receiver to the stereo one, i don't usually listen that loud and do prefer accuracy to volume, do i need a power conditioner though am i most likely clipping ? how can i tell ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • halo71
    halo71 Posts: 4,630
    edited January 2010
    My recent experience....I noticed that my speakers were sounding a little 'harsh' last month. First thought was the wifey had been "blasting" them and the mids or tweets were f'd up. Well after hooking up another pair of speakers, they sounded the same. Long story short it was my old AVR. After hooking up another AVR from my guitar room in the den. The harshness disappeared.
    --Gary--
  • concealer404
    edited January 2010
    Dan2036 wrote: »
    Power conditioner isn't going to keep you from clipping. You need more clean power. Better amplification first.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited January 2010
    Let's see what your doing here:
    Small room at high SPL levels: Overloading the room
    Sounds like hash at high SPL: clipping your AVR
    Using MP3: Useless
    Power Conditioning: No need at this point
    Corrective action:
    Amplification. Your AVR is not going to push any speaker to ear bleeding levels without clipping or massive distortion. Keep pushing it and you'll fry your speaks. You need amplification.
    Speakers. If your going for massive dorm room/club sound, look into club speakers ala JBL.
    Your source could use some improvement. An I-Pod is not the highest level of reproduction available.
    Your not ready for power conditioning yet. You can spend the dollars in more productive ways.
    Quality sound is not how many ears you can make bleed. If that's what your after, your probably in the wrong place.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    Even at reasonable levels you think that the HK's 3390's 80wpc is not enough ? I don't usually blast, i was just worried if that meant something was wrong with my set up, now i realize it's me putting the volume up to high. honestly the most important thing to me is clear full range audio not volume
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    edited January 2010
    As said above MP3 suck!
    But your CDP is also a very IMPORTANT factor...most cheaper CD players sound like A$$...especially when the volume goes up. Good quality DACs, jitter control circuits, noise reduction--and so on are asbolutely necessary in order to eliminate high end CD harshness (quantizatation errors). It is also possilble that some CDs themselves suck..
    Many recent CDs are being recorded by compressing the sound range and boosting their LOUDNESS so that they sound BIG and BAD in a tricked out car with 5000watts of sub power! But when you play them on a good system the recording problems become OBVIOUS.
    I'd recommend getting a new CDP as well? By a good used piece.
    cnh
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    So in everyone's opinion what would be the best things i could do to improve audio quality ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    is a ps3 a good CDP ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    edited January 2010
    PS3 is OK but not great...a simple fix is to buy an external DAC box and hook up the PS3 optical to it...this allows the better DACs in the box to decode the bitstream and reduce noise and jitter....and the PS3 serves merely as a CD transpost device...you would connect the DAC box via L/R analog cables to your AVR....
    There are a lot of DACs available...I think someone on this site was selling a cambridge audio DAC, Musical/Fidelity also sells some reasonably priced DACs...but remember you can spend upwards of 2000 dollars on DACs so we don't want to get too crazy here.
    Another option is to find a good used player like a Sony ES series or a Denon DVD 3910 Universal player, etc. either will give you better sound than you have now.
    cnh
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    First i need to buy some CD's ... and probably get a better sub because the psw10 is probably not a very musical sub
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Hawkeye
    edited January 2010
    Dan2036, what exactly are you looking for? Are you looking for a high SPL or an accurate presentation of music? It does make a difference.
    Gordon
    2 Channel -
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    Gordon, Accurate presentation of music is by far more important to me
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2010
    Very few AVR's can give really great sound at anything approaching high volume. If you want really great sound for music listening seperates or a really good integrated and a decent source is the way to go. My .02
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    So the HK 3390 isn't considered a really good integrated receiver ? By AVR do you mean the 5.1 or the Stereo one ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    tonyb Posts: 33,072
    edited January 2010
    Dan2036 wrote: »
    I think your missing the point. It's not that either receiver is bad, just that your asking more than it's capable of. Coupled with the crappy mp3 stuff your shoveling down it's throat, no way in hell you'll come close to good sound.
    edited January 2010
    I hate to speak for someone else but I do think he means surround Receivers.
    However a H/K 3390 is also a Stereo receiver and NOT an integrated amp or power amp and that is what Fongolio is talking about above.
    However I, myself, find it 'very' difficult to believe that your 3390 would sound 'harsh' even at reasonably high volumes. I really do think it is your source.
    H/Ks are 'warm' sounding and M60s are more laid back than let's say Rtis.
    Are you using the M60s with the 3390 also?
    That's NOT a harsh combo!
    cnh
  • concealer404
    edited January 2010
    cnh wrote: »
    cnh
    He's talking about hearing loss after listening. I wouldnt call that a reasonably high volume. :p
  • zombie boy 2000
    edited January 2010
    cnh wrote: »
    cnh
    Agreed. Like I mentioned previously, I have the exact same combo in my bedroom. -10 on the HK would be punishing on anybody's ears with this set-up unless you're running it in a cathedral (which the monitor 60's were obviously not meant to be used in).
  • Fongolio
    edited January 2010
    cnh wrote: »
    cnh
    Precisely. Thank you.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2010
    4 factors:
    -mp3; its tough enough to get smooth treble out of full resolution CD's, much less mp3
    -monitors will compress at high volumes; if you want LARGE scale (spl), you need LARGE speakers
    -possible clipping of the amp section
    -poorly engineered recording(s)
