Loud Music Sounds Harsh
Dan2036
Dan2036 Posts: 148
edited January 2010 in 2 Channel Audio
When i blast music it just seems to get really harsh sounding. The highs are just ear piercing. is that because i'm listening to mp3's or is it something about my system, or is this just a normal part of blasting ??
TV- Samsung 24" LCD T240HD
5.1 Receiver - Harman/Kardon AVR 247
Stereo Receiver - Harman/Kardon 3390
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD :D
Playstation 3
«13
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    It's because you're listening to MP3s. Don't do that.
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    What about imported music off cd's, as aiff's ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • concealer404
    edited January 2010
    I don't know what an aiff is.
    Either listen to lossless, or the cd itself.
  • coolsax
    coolsax Posts: 1,826
    edited January 2010
    or if you really have to listen to Mp3s at least get a decent DAC that might help too..but as concealer said go losseless or CD itself if you can
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    How much would a decent DAC cost ? Does my Receiver already have one ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    edited January 2010
    Agree on the MP3 thing, also dude, turn it down. Speakers have limits,your gear has limits, you keep pushing it,say goodby to those speaks.
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    What would be considered pushing it ? -10db on the Hk is about as loud as i'll go
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • concealer404
    edited January 2010
    Dan2036 wrote: »
    We don't know how loud that is on your gear, in your house, to your ears. ;)
    Your reciever has a DAC in it. But honestly, it won't matter. MP3 = garbage.
    Garbage in, garbage out.
    heiney9 Posts: 25,713
    edited January 2010
    coolsax wrote: »
    No it won't.............mp3's suck for fidelity.
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    So i'll stay away from mp3's but now you got me worried i'm pushing the speakers to much, is there anyway to tell ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2010
    You're only running 50watts RMS per channel (yes I know about HK).
    -10 is very very high on the volume scale. At -10db on my surround system windows are cracking and light fixtures are separating from the ceiling.
    At -10db on my 2 channel system you're talking permanent hearing damage.
    Also, your speakers are monitors, not made for blasting. If you want to blast get some SDA's or Klipsch. Your speakers can definitely use more than 50w rms as well if you want to blast.
    Main Surround -
  • concealer404
    edited January 2010
    Dan2036 wrote: »
    If it sounds bad, you're pushing too hard.
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    Well i'm using the Stereo receiver the HK 3390 which are 80w rms,
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    So the monitors aren't considered musical speakers ? or just not blasting speakers ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • ShinAce
    ShinAce Posts: 1,194
    edited January 2010
    +1
    Why didn't you just say that to begin with, instead of laying all the blame on mp3s?
    Seriously, turn it down before you blow the tweeters and try a few different recordings to see for yourself if it's the music or the speakers.
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    Oh i'm not complaining about the speakers they're great at normal volumes, just i guess not at the volumes i played them at. Explains the temporary hearing loss yesterday...
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
    edited January 2010
    nguyendot wrote: »
    Keep in mind every processor that is registering -10dB is not at the same volume level. It's just a scale representing where the volume is not an actuall measurement.
    You could out 5 processors/pre-amps in a system and set them all (according to each one's display readout) to -10dB and they would all put out a different level of sound.
    So to make a blanket statement that because your system is very very loud at -10dB everyone's is...................really is not true.
    That doesn;t mean the OP isn;t listening at too high a level.
  • coolsax
    edited January 2010
    yes if you have temporary hearing loss then it is too high
    Main 2ch -
    TV 3.1 system -
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    It's a small room though, i'm gonna partially blame it on that. So were the Monitor 60's meant more for theater or Music ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • coolsax
    edited January 2010
    heiney9 wrote: »
    I know, but I wasn't sure sure if a good DAC would help or not that's why I said might...
    Main 2ch -
    TV 3.1 system -
    edited January 2010
    coolsax wrote: »
    Tubes can help a little in some cases...............as nicer dac just makes mp3's even worse.
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    I just added the HK 3390 so not really looking to replace that anytime soon
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • nguyendot
    edited January 2010
    heiney9 wrote: »
    Yes I know -10db is not going to be the same across all systems, it's still very close to reference level (even though technically if it were true db it'd be over 5x louder at 0db). That should be pretty loud.
    Main Surround -
  • TroyD
    TroyD Posts: 13,124
    edited January 2010
    Yes, mp3 sucks.
    Also, I suspect that you are clipping the amp...and that harshness is probably straight DC frying your speakers.
    Read up on tinitus....
    Enjoy!
    BDT
  • tderks
    tderks Posts: 13
    edited January 2010
    How does it sound with other sorces? more than one issue here obviously, not to mention playing to lound.
    T
    Pre amp Adcom 870 HD
    Front Amps Adcom Gfa 8500 and Gfa 555II bi-amped
    Surround and center amps Adcom Gfa 2535, Gfa 5400
    Denon DVD-A1UDCI reference DVD
    Line conditioning 3 each Panamax M-5400-PM's with 30 amp supply
    Polk RTi's
    Velodine and M & K subs
    Audio Quest cables
    Starcase rack
  • nguyendot
    edited January 2010
    I'm telling you if you want loud get bigger speakers. My ForteII's are made for louuuud. My polks are made for 'awesome clear sound'.
    Main Surround -
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    With Cd's it always seems like i have to adjust the bass with each cd
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    But aside from being unbalanced they sound great
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • tderks
    tderks Posts: 13
    edited January 2010
    OK but is it Harsh, CD's vary greatly especially if it was from a crappy master. Make sure your not starving you amps for power.
    Polk RTi's
    Audio Quest cables
    Starcase rack
  • Dan2036
    Dan2036 Posts: 148
    edited January 2010
    Really loud ya it can get on the harsh side like you said depends on the CD, how do i know if i'm starving my amp ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
