kinda need help on DISHWASHER issue
doggie750
doggie750 Posts: 1,167
edited January 2010 in The Clubhouse
Got a KAid dishwasher and has issue with this 7 blinking clean cycle mode:mad:. Per my research, the heating element could be the candidate for this cause but I have no clue on how to check the amp if it's really at fault or not. Visually it looks good and the surface is smooth and no sign of bump to cause it to fail. Other factors are the door switch (checked, it's good), controller (checked) and water source (I doubt it, not checked), filter-clogged issue (un checked). Any Appliance Guru POLK breed out here to give me a helping brain.
Cheers
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • thsmith
    thsmith Posts: 6,082
    edited January 2010
    repairclinic.com is what I would do
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2010
    Break out a meter and read the heater element, I'm thinking in the range of >40 ohms or so. Power off please first.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited January 2010
    Problem with the dishwasher ? Smack her on the butt and tell her, "A little less yap-yap, and a little more scrubby-scrubby".
  • obieone
    obieone Posts: 5,077
    edited January 2010
    "7 blinking lights" sounds like an error code? Which could be a monitoring switch is not satisfied; It may be a pressure switch in the sump/ pump housing saying that it's safe to turn on the pump or heat?
    Really need more info. and a schematic to tell ya more.
    Sorry
  • NotaSuv
    NotaSuv Posts: 3,871
    edited January 2010
    hhhhhhhhhmmm sounds like you have the same model I have
