Two Channel stereo and TV
joeygrand3
joeygrand3 Posts: 41
edited January 2010 in 2 Channel Audio
This may be a dumb question, but I do need some expert advice. How do I configure a two channel vintage stereo unit(Sansui) to get audio from my TV? The back of the receiver only has inputs for a tape player and/or a phonograph. I do have the speakers. [/B]
Post edited by joeygrand3 on
  • MANSKITO
    MANSKITO Posts: 295
    edited January 2010
    just plug it in the tape input, the only one that won't work properly is the phonograph. Just because its says tape dose not mean thats all you can plug into it, you can plug any thing from cds to a blu-ray player into that input and it will sound fine. (just make sure white gos to white and red to red and if its not color coded white gos to Left and red to right)
    Monitor 60s, CS10 front
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    Pioneer PD-5010 CD player
    Sennheiser HD 650s :D
    Maverick Audio Tube Magic D1 DAC
    AMD Phenom II 940 @ 3.8 prime stabel
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
    Creative X-fI Titanium Fatal1ty
  • joeygrand3
    edited January 2010
    Thanks, I will try that . It does make sense. I will let you know how I made out.:
  • George Grand
    George Grand Posts: 12,256
    edited January 2010
    If the tv audio outputs are variable, you may have remote volume also (only over the tv signal).
    edited January 2010
    We're assuming, of course that your TV does have L/R RCA OUTS! RIGHT??
    Without those you'll need another soluton like a VCR or a Cable box with audio OUTS!
    cnh
