Two Channel stereo and TV
joeygrand3
This may be a dumb question, but I do need some expert advice. How do I configure a two channel vintage stereo unit(Sansui) to get audio from my TV? The back of the receiver only has inputs for a tape player and/or a phonograph. I do have the speakers. [/B]
Post edited by joeygrand3 on
just plug it in the tape input, the only one that won't work properly is the phonograph. Just because its says tape dose not mean thats all you can plug into it, you can plug any thing from cds to a blu-ray player into that input and it will sound fine. (just make sure white gos to white and red to red and if its not color coded white gos to Left and red to right)Monitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty -
Thanks, I will try that . It does make sense. I will let you know how I made out.:
If the tv audio outputs are variable, you may have remote volume also (only over the tv signal).
We're assuming, of course that your TV does have L/R RCA OUTS! RIGHT??
Without those you'll need another soluton like a VCR or a Cable box with audio OUTS!
