PSW 505 No sound
Raven47326
Need Cheap Help
No sound out of PSW505. Hooked cd player into back of sub (suggested by Polk Tech Support) and only slight static heard when sub turned to max volume setting. Out of warranty 8 months (bought 05/04/2006) has not worked in 3 or 4 months. I saw other people helped without sending sub in hope someone can help me, work cut hours last year 20%. Back to full time now but catching up. Can I check volts or Ohms to try and determine anything.
Thanks, Brian
Thanks, Brian
Post edited by Raven47326 on
Hi im also having problems with my 505 sub. its been working find for 4 month and then all of a sudden no sound what so ever comes out of the sub not even hum noise. The green light comes on when its connected to my reciever and when i try my signal tests from my onkyo menu i get no sound. I know its not the cable because the green light comes on as soon as i turn on my tv with my sub set to auto. I tried to hook up my sub to a cd player to see if its my reciever but i still get no sound. Im still under warranty with Polk but i would like to know what would cause my sub to just stop working so i can be more educated on the subject. I dont like making the same mistake twice, i need to know if its just bad luck or something i did. I listen to my sub at 50% volume and set my reciever to out put at +2 db for sub so i dont listen at extreme volumes. Thanks in advance!
Call the number at the top right of the page, and Polk will do their best to take care of ya. I've dealt with them on a few different occasions, and they always go out of their way to help! Probably some of the best CS around IMO! Oh, and make sure and mention you are a Club Polk member, you will get a discount with free shipping if you have to purchase parts. Good Luck:)Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
Hey Game, it might just be one of those things. Not really sure what it is that is wrong, but call Polk CS and they will get you fixed up in no time, and welcome to Club Polk.
-Jeff
1-800-377-POLK (7655)
9AM-5:30PM EST Mon-FriHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
I have been dealing with Eric Wong (Polk Audio Customer Service/Technical Support). He has given me a few things to check to help narrow down the problem and parts are now on the way. The customer service here has been great. I was surprised after having to deal with Microsoft CS :mad: which was terrible. Glad customers still matter to Polk.
Breanna Diaz ( polkaudio Customer Service Representative-Technical Support) is sending me a new amp and subwoofer gasket. Im glad Polk has good Customer service. Im on my third 360 and each time my 360 red ringed Microsoft wanted me to pay 100 dollars to get it repaired, the dam system all ways red rings when your out of warranty, its almost like MS designs the systems to break after a certain amount of time.
I've dealt with Brianna as well, and she was very helpful for me. Polk CS ROCKS!!!Sony 40" LCD
Sony DVPCX995V
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
Got my part the other night, put it in and I have sound again. Thanks again Polk and Eric!!!!!!!!
Brian:):):)
