Polk SDA-CRS
Toolfan66
Toolfan66 Posts: 18,183
edited March 2010 in Vintage Speakers
Post edited by Toolfan66 on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2010
    I would say that is a pretty good price. You could offer a little lower. Those are the most sought after CRS design. Go Go Go!!!!!!!!!!!!!!!!!!!!
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • engtaz
    engtaz Posts: 7,669
    edited January 2010
    Grab them now. Just remember that your setup for CRS's is more precise to get the best sound.
    engtaz
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2010
    Definitely worth the asking price but as always offer a little less.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Go for it Larry that is a good price and you can do the 4.1 TL upgrade to them.
  • leroyjr1
    edited January 2010
    Denver and Phoenix has alot of sda's.
  • Conradicles
    Conradicles Posts: 6,376
    edited January 2010
    Plus they are the easiest and cheapest SDA's to ship if you want to sell them.
    Get them for your birthday LOL.
  • tx_polkhead
    tx_polkhead Posts: 248
    edited January 2010
    I am very happy with mine (these look like CRS+ right?). I paid less with stands but as I often think and say I'd be quite happy at twice the price I paid!
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
    F1nut Posts: 51,997
    edited January 2010
    I can't tell from the pics, but I think those are blade/blade CRS+'s since they are 1987/1988 versions. The TL upgrade was designed for the pin/blade version.
  • stubby
    stubby Posts: 723
    edited January 2010
    I think you are right about them being blade/blade models. About the TL mod on them, what exactly is the difference between the CRS+/SDA 2B with dual blade vs. the same model with pin blade? I have a pair of 2B's with dual blade IC and the crossover appears to be the same as on the pin/blade.:confused:
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
    F1nut Posts: 51,997
    edited January 2010
    Stubby, I knew someone was going to ask....
    The blade/blade version has a 2.7 ohm resistor in series with the 0.4mH coil that is not used with the pin/blade version. A simple fix by removing the resisitor. However, the blade/blade version uses a different SDA driver and assoicated circuit. Therefore, some concern is raised as to the balance of the sound if one were to do the TL upgrade on the blade/blade version. Who feels like being the guinea pig?
  • hearingimpared
    edited January 2010
    uh oh!
  • stubby
    stubby Posts: 723
    edited January 2010
    Thanks for the info!! Maybe after I get done sorting out the SRS 2's, I will try my luck with TLing the 2B's.
    stubby
    SRS 3.1TL
    Anthem AVM2
    F1nut Posts: 51,997
    edited January 2010
    Stubby, I missed that you were asking about 2B blade/blade speakers. I thought you were asking about CRS+ blade/blade.
    Your 2B's do not have the second 2.7 ohm resistor I mentioned, so all you need to do is add the 5.8uF cap and change the tweeters to RD0198-1's.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited January 2010
    So....just looking at the pictures, does anyone suspect he listened to them in that position?
  • xj4094dg
    xj4094dg Posts: 1,158
    edited February 2010
    I have the pin/blade version. Can you direct me to/provide me with a complete shopping list for the TL upgrade?
    Thanks.
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
    F1nut Posts: 51,997
    xj4094dg wrote: »
    Thanks.
    The mod is easy to do, simply add a 5.8uF cap in the C5 position and change the tweeter to the RD0198-1. Of note, the bottom lead of the 5.8 cap has to go into the hole marked "H", the top lead goes into the top C5 hole next to R2.
  • stubby
    stubby Posts: 723
    Sometimes it is difficult to find a 5.8 value cap available "off the shelf". I think many people talk with the fine folks at Sonicaps and custom order their nice caps. I believe its only a buck extra.
    stubby
    SRS 3.1TL
    Anthem AVM2
  • squeeb
    squeeb Posts: 426
    edited March 2010
    Did you get them??? Hope all of us Coloradans are able to get together (at your house???) sometime.
    7.3 HT: Sunfire TGR-3, Sunfire Series II, Mirage OMD-28, OMD-5 (x4), REL T1 (2), T2, Oppo 103D, Optoma HD8200PRO, 106" screen, SB Touch
    Family Room: Yamaha RX-V2700, RT25i, 42" Samsung, SB Duet
    Pool: Yamaha V2700, SQ Duet, Atrium 60 (2), Atrium 45 (3), Atrium 65sdi
    edited March 2010
    squeeb wrote: »
    If it happens at my house it will be a few as I have a couple of projects going on for the wife as well as my own..;)
    No I passed on them as I am pursuing a set of 3.1's and 2.3tl's not that I need the damn things just hooked on them right now..:cool:
  • zarrdoss
    zarrdoss Posts: 2,562
    edited March 2010
    They have been re-listed, I sold the guy an amp, nice guy.
    http://denver.craigslist.org/ele/1618741964.html
