Oppo BDP-83 Special Edition - Sabre 32 DAC
1235»
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2010
    I'd like to hear the Nufoce as well and/or any of the signifcantly modded Oppos, but for the money, I can't complain with what we got.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Ron Temple wrote: »
    No kidding. I am at a loss as to why we are the only ones here talking about it. :cool:
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Ron Temple
    edited January 2010
    vc69 wrote: »
    Likely we're the only Polkies that did it...:D
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2010
    vc69 wrote: »
    Not really except to say that the redbook (CD) performance is much, much improved over the standard player in my opinion. I highly recommend the SE for anyone doing analog audio out from this player. I wish I could hear the NuForce to compare.
    Do you play any SACD's on it at all??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    vmaxer wrote: »
    Sure do and I believe it is improved as well. However, I was pretty happy with the SACD performance before. I really haven't done much SACD listening since the upgrade. Only a couple titles.
    I haven't listened to any of my DVD-A's yet. I think Ron has done some DVD-A listening and could comment.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • snow
    snow Posts: 4,358
    edited January 2010
    vc69 wrote: »
    Ron Temple wrote: »
    There will be others soon :D I am just waiting to see how much I owe uncle sam before I commit any money to anything audio at the moment but I assure you before the end of the year the SE or NuForce model will be mine.
    REGARDS SNOW
  • SolidSqual
    SolidSqual Posts: 5,218
    edited January 2010
    snow wrote: »
    REGARDS SNOW
    I wonder how the nuforce model compares to the modwright model. It seems both rework the signal paths. Modwright claims there are no opamps in the signal path whatsoever and installs custom power supplies. That being said, the upgrade is at least $500 to $1000 more expensive.
    Also, how much better is the nuforce than the SE?
  • snow
    snow Posts: 4,358
    edited January 2010
    SolidSqual wrote: »
    Not sure what the percentages would be of improvement as you go up the upgrade path. One thing that does concern me though is that after a certain price point when does stand alone units become more attractive? Also with chip tecnlogy advancing so quickly todays digital winners can and usally are beaten by a much better and cheaper product.
    That being said at some point one has to jump in and commit, you could wait forever or at least till the current formats are replaced if one continued in this vent.
    I was just reading another thread on HD TV's versus 3D tvs and the whole should I wait issue.
    REGARDS SNOW
  • SolidSqual
    edited January 2010
    snow wrote: »
    REGARDS SNOW
    I was all set to buy this thing and then I heard a tube CDP that just made all my redbook cds sound new again. I'm at a loss. The tube CDP is nearly as much as the nuforce. I'm torn between my new HT system and my old two channel glory trying to creap back.
