Wich rf remote ????
Neale13
i need a rf universal remote to run my cable box,receiver wich are located in another room.
who makes good ones thanks
Post edited by Neale13 on
I prefer the Harmony remotes. I know that the 890 does RF, i think the Harmony One does as well as some of the more expensive ones.
+1 on the Harmony remotes. I owned an 880 and it was awesome. To clarify Zeros' post, the 890 does RF, the Harmony One does not.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
I haven't used Harmony but own and love several Universal Remote Control (URC) RF remotes, including the MX-800, MX-850, and MX-950.
Good luck!Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I have used Harmony, and got rid of it within two months. Prior, I had a URC MX-500&IR Clone combo for many years. I figured I'd try a Harmony, and found out I absolutely hated their programming interface. The Harmony remotes feel much lighter weight, which for me, translated to a 'cheaper' feel.(YMMV)
I'll say this about Harmony remotes, if you have a very few components to control, they can't be beat for the simplicity, but if you need anything more advanced, look elsewhere.
I currently use a URC MX-880, and it's fantastic. You can program it to do things the way YOU want, instead of having to 'trick' it into doing so, as with Harmony. As with any of the URC professional remotes, you need to make sure you're getting them from an authorized dealer, or you won't have the programming software. (IOW, don't buy one from flea bay) -
To prevent errors when buying Logitech remotes, the Harmony One DOES NOT have RF. The newer Hamony 900 does. Hope this helps.
Mikepolkaudio
Currently Own:
RTA-11T Light Oak, Aug/2011 to present
SDA-CRS+ Aug/2011 to present
RTA-11T Black, Dec/2013 to present
Previously Owned:
SDA-SRS 2.3 May/1990 to June/1991
SRS 1.2TL June/1991 to May/1995
SDA-1C Aug/2005 to Dec/2011
SRS 1.2TL Sept/2009 to Sept/2015 -
You don't need a RF remote. Just buy on ebay the Radio Shak RF repeater. They look like small black pryminds. Cost about $40 EBay. You then can use ANY REMOTE.
anonymouse wrote: »I'm not sure how well the Radioshack ones work, but the Belkin version of this is useless. CFL bulbs interfere with it and it would have serious range problems. I finally switched to a wired IT repeater, which works well.
Good points anonymouse.
I have used themfor 15 years and they work well.
Hear are a few hints.
Bulbs: Rotate the transmitter and reciever for best results. Experi9emnt with positions. Some times pointing them in different directions helps.
The range depends on the number and thickness on the walls. YMMV. RF remotes have the same issue however.
The closer the reciever is to the equipment the better.
They work as well as the RF remotes that I have also tried.
The old Radio Shak model looks like a pyrimind and is sold only on ebay cheap. The new model costs more money.
I even used one outside for 3 years near my hot tube and I live MA. I just locate it under the porch so it doesn't get wet.
Finally they will allow All your remotes do work like a RF remote.
I love locating all my equipment out of sight and in closets.
Have a blast -
i use the next generation remote extender...it works perfectly for my denon and cable box located in another room...for $40 you cant go wrongTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3 -
Is that from radio Shack?
