How to Clean the Pots of Vintage Gear
Conradicles
Title says it all.
What exactly does it mean to "clean the pots" and how does one go about doing this?
Links or personal experience would be greatly appreciated.
Thanks folks.
Thanks folks.
Post edited by Conradicles on
Fill tub with bubble bath, get in, begin cleaning when wife drops gear inside aforementioned bathtub. Check for power cord before or after filling the tub.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
This stuff is the shiznit in my eyes! I have used it on guitar pots and amp pots for several years now. Works like a charm!
http://www.stewmac.com/shop/Accessories/Cleaners,_polishes,_lubricants/DeoxIT_Pot_and_Switch_Cleaner.html--Gary--
The process consist of opening your gear to make sure you have access to the back of of the canister (enclosure) of the trim pots. Then locate the small opening that will allow you to inject the cleaner. you can use contact cleaner from Radio Shack or if you have an electronic component provider you could check for MG Chemicals SUPER CONTACT CLEANER 4.5 oz or smaller. Make sure you use the provided straw to inject the product. You then rotate the control many times and check for improvement. If there is no improvement, you start the process all over again. However, at times this will not work and you simply might have to replace the pot as the fine resistive contact which the leaf spring contact rides on may simply be worned and will not make contact in some aeras (just like a run that would be cut on a circuit board). WD40 can also be used but some claims it lives residue odd, I used it for so many times for my customers, never a single complaint or come back.
Good luck!
TKDARE TO SOAR:
I'm stupid in this matter and i'm about to hit the internet more now. Just spraying the deoxit down the shaft does the trick? do you have to wait 5 hrs. for it to dry or what? I always thought you had to go inside and flood the round part or even open one up to spray it.Going on the google..Most people just listen to music and watch movies. I EXPERIENCE them.
Thanks TK, but I am going to stick with Doro's way of doing it.;)
When I was in the military we had a sonic bath which was used with special cleaner and yet this could do the cleaning of the electronics in one shot so your joke actually has some form of truth, "reality surpasses fiction" rightFill tub with bubble bath, get in, begin cleaning when wife drops gear inside aforementioned bathtub. Check for power cord before or after filling the tub.
? DARE TO SOAR:
CAIG DeOxit is the best contact cleaner going.
http://www.audiokarma.org/forums/showthread.php?t=207005 -
Definitely a great step by step post :cool:mhardy6647 wrote: »CAIG DeOxit is the best contact cleaner going.
http://www.audiokarma.org/forums/showthread.php?t=207005DARE TO SOAR:
I use CAIG exclusively, simply because it works great."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
I seems to be a good bang for the buck too, right?I use CAIG exclusively, simply because it works great.DARE TO SOAR:
Not when you could use it in gallons.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I don't understand what yo mean, a can of cleaner should last a long time...Not when you could use it in gallons.DARE TO SOAR:
Thanks:DMost people just listen to music and watch movies. I EXPERIENCE them.
It is a bit pricey as far as that stuff goes. Ratshack stuff is cheaper but I have more confidence in the CAIG"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
tony millard wrote: »Just spraying the deoxit down the shaft does the trick? do you have to wait 5 hrs. for it to dry or what? I always thought you had to go inside and flood the round part or even open one up to spray it.Going on the google..
On guitar pots I have just sprayed it on the pot without taking it out or apart. On amp pots I take the pot out and opened it up to spray. I even use DeOxit on 1/4" phono plugs.--Gary--
I use Caig all the time. Not only for stereo gear, but pretty much anything electronic where applicable. If you knew me and what I do, you'd understand. The little Caig canisters you get at Rat Shack sometimes only lasts me one night. That gets a little expensive after a while.I don't understand what yo mean, a can of cleaner should last a long time...~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
As they say quality has its price, this is the main reason I always bought MG products over RS products. It is nice to know there is even better product out there now (this is not the first time deoxit has been praised on this site). When you look on CAIG site, they offer both deoxit and CAIG, what is the difference between them?It is a bit pricey as far as that stuff goes. Ratshack stuff is cheaper but I have more confidence in the CAIGDARE TO SOAR:
I have the DeOxit, but I was wondering how to use it properly to clean the pot. But after reading all of this good info, I get it. Thanks to all.
However, the longevity of your gear is prolonged not counting the savings of giving the job to a repair shop. I was not abusive when doing such for my clients but labor is usually the expensive part of the tab. Buying the cleaner and DIY gets the product to pay for itself pretty quickly.I use Caig all the time. Not only for stereo gear, but pretty much anything electronic where applicable. If you knew me and what I do, you'd understand. The little Caig canisters you get at Rat Shack sometimes only lasts me one night. That gets a little expensive after a while.DARE TO SOAR:
^ That is a good point about longevity! I am sure original pots in a collectable vintage amp make it more valuable to a collector.--Gary--
conradicles wrote: »thanks tk, but i am going to stick with doro's way of doing it.;)
LOL
Please make out a living will first....Doro isn't my first name.
CAIG is the nectar of the gods.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I agree, keeping/maintaining original parts add to the value not counting that newer (chinese) parts will never last as long and probably not provide for the original quality. I had to replace some drivers in vintage speakers with non OEM because the OEM is no longer available and the quality is definitely not the same. I just hope someday I'll be able to put my hands on used just for the parts. Believe me, once I do, the non OEM modern drivers will be out pretty quickly. When a piece of gear was behong repair, I always made sure to keep the valuable parts (the main reason for my house to be such a mess, thus likely I didn't have the choice to depart with a lot of thoses parts unfortunately)^ That is a good point about longevity! I am sure original pots in a collectable vintage amp make it more valuable to a collector.DARE TO SOAR:
Conradicles wrote: »I have the DeOxit, but I was wondering how to use it properly to clean the pot. But after reading all of this good info, I get it. Thanks to all.
Just liberally spray the part, work it around as you do so and let it dry. I've had components that needed a couple rounds of cleaning depending on the age. Try to get the nozzle or tube as inside the actual part as possible.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Conradicles wrote: »Title says it all.
Lots of good advice so far. Just in case you are wondering what "pots" are, pots is shorthand for potentiometers, which are variable resistors. They are used as volume, balance, and other controls where changing the resistence can change the outcome. They are mechanical, and dirt, etc. can build up over time which negatively affects the resistence. Cleaning is getting rid of the dirt so that good electrical contact is made throughout the range of the pot.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
.. When you look on CAIG site, they offer both deoxit and CAIG, what is the difference between them?
Caig is the brand name, Deoxit is the product line name. Caig makes deoxit.____________________
Pool: Atrium 60's/45's -
In a thread at DIYAudio regarding my DIY repair of an Adcom 5800, I mentioned that while I had all the parts out I used Deoxit Gold on all the connection points, such as where the B+ and B- rail wires connect to the driver/MOSFET output stages or where the output connects to the actual speaker out binding posts (blade style connectors). I was about to also use it on all the MOSFET leads too.
I gathered from Anatech's responses that one should NEVER use any kind of treatments on the higher voltage or current connections. That whatever is used should leave ZERO residue.Clean every trace of your contact cleaner out of the sockets or connectors. They, like power relay contacts, must be both clean and dry. There should be no films or anything else applied to them. The product you need to use is something like Electrowash PX or similar. It needs to attack greases and oils, wash them out and leave no (as in zero) residue. This is very important. Why? Because any film or coating may oxidize or arc. This will build up a non-conductive film that promotes arcing.
So what are 'yall' thoughts? Is he more or less concerned only with the internals of an amp? Is it safe or even recommended to use DeOxit Gold on Speaker connections (binding posts and cables, etc), or only on the RCAs?
What about on the prongs on an AC cord?____________________
Here's an interesting post about a negative to using Deoxit on pots. Well not completely, but requires extra steps.
http://www.audiokarma.org/forums/showpost.php?p=2458122&postcount=21____________________
One does have to be a little careful with DeOxit, but one should be careful with everything under the hood of a piece of audio equipment, vintage or new.
Here's my little DeOxit testamonial, FWIW. I have an old McIntosh C-28 preamp (it's really pretty mediocre; stick with vacuum tubed Mac stuff if you can). The function selector switch was dirty. I used Radio Shack's contact cleaner on it several times, but the phono sections of the switch were iffy at best. After reading a lot on line about DeOxit, I ordered a can from Parts Express and tried it on the C-28. It worked like a charm. Never bothered with any other contact cleaner (even name brands such as GC) since. -
Everyone is correct. De-Oxit is the hot ticket. They also make a fader lube. Good general practice to lessen cleaning intervals is approx. every 2 weeks ( un-powered ) FULLY rotate knobs both directions to the mechanical stops about twice. Keeps oxidation from building up in 1 spot.
