How to Clean the Pots of Vintage Gear
Conradicles
Conradicles Posts: 6,339
edited January 2010 in Electronics
Title says it all.
What exactly does it mean to "clean the pots" and how does one go about doing this?
Links or personal experience would be greatly appreciated.
Thanks folks.
Post edited by Conradicles on
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    Fill tub with bubble bath, get in, begin cleaning when wife drops gear inside aforementioned bathtub. Check for power cord before or after filling the tub.
  • thsmith
    thsmith Posts: 6,082
    edited January 2010
  • halo71
    halo71 Posts: 4,630
    edited January 2010
    This stuff is the shiznit in my eyes! I have used it on guitar pots and amp pots for several years now. Works like a charm!
    http://www.stewmac.com/shop/Accessories/Cleaners,_polishes,_lubricants/DeoxIT_Pot_and_Switch_Cleaner.html
    --Gary--
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited January 2010
    The process consist of opening your gear to make sure you have access to the back of of the canister (enclosure) of the trim pots. Then locate the small opening that will allow you to inject the cleaner. you can use contact cleaner from Radio Shack or if you have an electronic component provider you could check for MG Chemicals SUPER CONTACT CLEANER 4.5 oz or smaller. Make sure you use the provided straw to inject the product. You then rotate the control many times and check for improvement. If there is no improvement, you start the process all over again. However, at times this will not work and you simply might have to replace the pot as the fine resistive contact which the leaf spring contact rides on may simply be worned and will not make contact in some aeras (just like a run that would be cut on a circuit board). WD40 can also be used but some claims it lives residue odd, I used it for so many times for my customers, never a single complaint or come back.
    Good luck!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    Tony M Posts: 11,615
    edited January 2010
    I'm stupid in this matter and i'm about to hit the internet more now. Just spraying the deoxit down the shaft does the trick? do you have to wait 5 hrs. for it to dry or what? I always thought you had to go inside and flood the round part or even open one up to spray it.Going on the google..
  • Conradicles
    edited January 2010
    Thanks TK, but I am going to stick with Doro's way of doing it.;)
  • TECHNOKID
    edited January 2010
    dorokusai wrote: »
    When I was in the military we had a sonic bath which was used with special cleaner and yet this could do the cleaning of the electronics in one shot so your joke actually has some form of truth, "reality surpasses fiction" right ;) ?
    DARE TO SOAR:
    mhardy6647 Posts: 34,994
    edited January 2010
  • TECHNOKID
    edited January 2010
    CAIG DeOxit is the best contact cleaner going.
    http://www.audiokarma.org/forums/showthread.php?t=207005
    Definitely a great step by step post :cool:
    DARE TO SOAR:
    heiney9 Posts: 25,431
    edited January 2010
    I use CAIG exclusively, simply because it works great.
  • TECHNOKID
    edited January 2010
    heiney9 wrote: »
    I seems to be a good bang for the buck too, right?
    DARE TO SOAR:
    treitz3 Posts: 19,985
    edited January 2010
    Not when you could use it in gallons.
  • TECHNOKID
    edited January 2010
    treitz3 wrote: »
    I don't understand what yo mean, a can of cleaner should last a long time...
    DARE TO SOAR:
    edited January 2010
    Thanks:D
    edited January 2010
    TECHNOKID wrote: »
    It is a bit pricey as far as that stuff goes. Ratshack stuff is cheaper but I have more confidence in the CAIG
  • halo71
    halo71 Posts: 4,630
    edited January 2010
    On guitar pots I have just sprayed it on the pot without taking it out or apart. On amp pots I take the pot out and opened it up to spray. I even use DeOxit on 1/4" phono plugs.
    --Gary--
    edited January 2010
    TECHNOKID wrote: »
    I use Caig all the time. Not only for stereo gear, but pretty much anything electronic where applicable. If you knew me and what I do, you'd understand. The little Caig canisters you get at Rat Shack sometimes only lasts me one night. That gets a little expensive after a while.
  • TECHNOKID
    edited January 2010
    heiney9 wrote: »
    As they say quality has its price, this is the main reason I always bought MG products over RS products. It is nice to know there is even better product out there now (this is not the first time deoxit has been praised on this site). When you look on CAIG site, they offer both deoxit and CAIG, what is the difference between them?
    DARE TO SOAR:
  • Conradicles
    edited January 2010
    I have the DeOxit, but I was wondering how to use it properly to clean the pot. But after reading all of this good info, I get it. Thanks to all.
  • TECHNOKID
    edited January 2010
    treitz3 wrote: »
    However, the longevity of your gear is prolonged not counting the savings of giving the job to a repair shop. I was not abusive when doing such for my clients but labor is usually the expensive part of the tab. Buying the cleaner and DIY gets the product to pay for itself pretty quickly.
    DARE TO SOAR:
  • halo71
    halo71 Posts: 4,630
    edited January 2010
    ^ That is a good point about longevity! I am sure original pots in a collectable vintage amp make it more valuable to a collector.
    --Gary--
  • dorokusai
    edited January 2010
    thanks tk, but i am going to stick with doro's way of doing it.;)
    LOL :D Please make out a living will first....Doro isn't my first name.
    CAIG is the nectar of the gods.
  • TECHNOKID
    edited January 2010
    halo71 wrote: »
    I agree, keeping/maintaining original parts add to the value not counting that newer (chinese) parts will never last as long and probably not provide for the original quality. I had to replace some drivers in vintage speakers with non OEM because the OEM is no longer available and the quality is definitely not the same. I just hope someday I'll be able to put my hands on used just for the parts. Believe me, once I do, the non OEM modern drivers will be out pretty quickly. When a piece of gear was behong repair, I always made sure to keep the valuable parts (the main reason for my house to be such a mess, thus likely I didn't have the choice to depart with a lot of thoses parts unfortunately)
    DARE TO SOAR:
  • dorokusai
    edited January 2010
    Just liberally spray the part, work it around as you do so and let it dry. I've had components that needed a couple rounds of cleaning depending on the age. Try to get the nozzle or tube as inside the actual part as possible.
  • BlueFox
    BlueFox Posts: 15,251
    edited January 2010
    Title says it all.
    Lots of good advice so far. Just in case you are wondering what "pots" are, pots is shorthand for potentiometers, which are variable resistors. They are used as volume, balance, and other controls where changing the resistence can change the outcome. They are mechanical, and dirt, etc. can build up over time which negatively affects the resistence. Cleaning is getting rid of the dirt so that good electrical contact is made throughout the range of the pot.
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2010
    TECHNOKID wrote: »
    .. When you look on CAIG site, they offer both deoxit and CAIG, what is the difference between them?
    Caig is the brand name, Deoxit is the product line name. Caig makes deoxit.
    ____________________
    Pool: Atrium 60's/45's
  • mmadden28
    edited January 2010
    In a thread at DIYAudio regarding my DIY repair of an Adcom 5800, I mentioned that while I had all the parts out I used Deoxit Gold on all the connection points, such as where the B+ and B- rail wires connect to the driver/MOSFET output stages or where the output connects to the actual speaker out binding posts (blade style connectors). I was about to also use it on all the MOSFET leads too.
    I gathered from Anatech's responses that one should NEVER use any kind of treatments on the higher voltage or current connections. That whatever is used should leave ZERO residue.
    Clean every trace of your contact cleaner out of the sockets or connectors. They, like power relay contacts, must be both clean and dry. There should be no films or anything else applied to them. The product you need to use is something like Electrowash PX or similar. It needs to attack greases and oils, wash them out and leave no (as in zero) residue. This is very important. Why? Because any film or coating may oxidize or arc. This will build up a non-conductive film that promotes arcing.
    So what are 'yall' thoughts? Is he more or less concerned only with the internals of an amp? Is it safe or even recommended to use DeOxit Gold on Speaker connections (binding posts and cables, etc), or only on the RCAs?
    What about on the prongs on an AC cord?
  • mmadden28
    edited January 2010
    Here's an interesting post about a negative to using Deoxit on pots. Well not completely, but requires extra steps.
    http://www.audiokarma.org/forums/showpost.php?p=2458122&postcount=21
    edited January 2010
    One does have to be a little careful with DeOxit, but one should be careful with everything under the hood of a piece of audio equipment, vintage or new.
    Here's my little DeOxit testamonial, FWIW. I have an old McIntosh C-28 preamp (it's really pretty mediocre; stick with vacuum tubed Mac stuff if you can). The function selector switch was dirty. I used Radio Shack's contact cleaner on it several times, but the phono sections of the switch were iffy at best. After reading a lot on line about DeOxit, I ordered a can from Parts Express and tried it on the C-28. It worked like a charm. Never bothered with any other contact cleaner (even name brands such as GC) since.
  • Krazyz1
    Krazyz1 Posts: 256
    edited January 2010
    Everyone is correct. De-Oxit is the hot ticket. They also make a fader lube. Good general practice to lessen cleaning intervals is approx. every 2 weeks ( un-powered ) FULLY rotate knobs both directions to the mechanical stops about twice. Keeps oxidation from building up in 1 spot.
