Bi-Wiring clarification needed
SangYuP
SangYuP Posts: 35
I purchased some RTi8's today and I need some clarification on biwiring. I have a Yamaha HTR-5860 that these speakers will connect to. I understand that 2 pairs of speaker wire will be going to each speaker, but the end that goes into the receiver is where I need clarification. Do both of the speaker wires from the speaker (2 + and 2 -) go into one channel? For example, if it's the right speaker, will the 2 + cables go into the single right + terminal and same as the left channel? Basically are you combining the cables from the speakers and putting 2 cables into a single terminal? Is this safe with all receivers?
Post edited by SangYuP on
  • ben62670
    ben62670 Posts: 15,969
    edited September 2008
    First welcome to Club Polk.
    Yes that is how you BiWire. What kind of wire are you using?
    Ben
    Ben
  • SangYuP
    SangYuP Posts: 35
    ben62670 wrote: »
    Ben
    Thank you for the warm welcome. I don't have any additional wires right now, but does it matter what kind I get? Do you have any cheap recommendations? By the way, I'm replacing my Athena AS-F2 with the RTi8. I wonder how much improvement I will hear? I'm also getting the CSi3 to match the RTi8.
  • ben62670
    For cheap wires I recommend AudioQuest type4's. You can buy these used pretty cheap. Monster is over rated over priced. Signal cables are a good choice also. One good set of wires is better than two cheap sets. As for the Athena's I have never heard them.
    http://cgi.ebay.com/Audioquest-Type-8-biwire-10-ft-pair-new-spades_W0QQitemZ110288115709QQcmdZViewItem?hash=item110288115709&_trkparms=72%3A1163%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
    http://cgi.ebay.com/Audioquest-Type-4-Speaker-Cable-8ft-2-5M-X2_W0QQitemZ300258061925QQcmdZViewItem?hash=item300258061925&_trkparms=72%3A1163%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
    Take your time, and get a good deal. You can also buy AQ type4 new at $4 a foot. If you are looking for super cheap wire check out WalMart in the automotive section. Not the electronics, but the automotive section for the 14 ga wire.
    Ben
    Ben
  • SangYuP
    SangYuP Posts: 35
    ben62670 wrote: »
    Ben
    I was actually thinking about getting regular 12 AWG or 10 AWG speaker wires from monoprice.com. Is it okay to use 2 pairs of regular speaker wires instead of premade bi-wire cables? The TYPE4 cables look really nice, but I noticed that there are banana plugs on the ends. I guess I would have to modify one end (the end that goes into the receiver) since the receiver post cannot accommodate 2 sets of banana plugs.
  • ben62670
    Monoprice is a good place to shop. You can use two cables no problem if you want, but you would be better off with one set of nice cables. I saw you were in GA. I am up in Conyers. If you ever want to make the trip, or are in the area you are more than welcome to stop by.
    Ben
    Ben
  • SangYuP
    SangYuP Posts: 35
    ben62670 wrote: »
    Ben
    Thanks for the information and the invite. I'll let you know if I'm ever in the area.
  • ben62670
    No problem
    A lot of cool Polkies in the area.
    Ben
    Ben
  • LandShark
    LandShark Posts: 130
    Ok, I have a question about bi-amping. I am new to this technique and I'd like to know the pros and cons to bi-amping. My current set-up is as follows...
    Onkyo 705 (5.1 setup)
    Polk CS2 center
    Polk Monitor 70 mains
    Polk RM101 surrounds
    Velodyne VRP1000 sub
    TV: Samsung LN40A550
    Mains: Polk Monitor 70's
    Center: Polk CS2
    Surrounds: Polk OWM3's
    Receiver: Onkyo TX sr705
    BDP: Sony S350
    Subs: Velodyne VRP1200 and VRP1000
    Monster Power Conditioner EP IR 2450
  • vonnie123
    vonnie123 Posts: 326
    Welcome to the forum Sang. I just built some bi-wire sets, and Canare 4S11 does a great job; price is just above $1 a foot. My cables were set up banana to bi-banana. The wire is available online at Blue Jeans Cable. Parts express has some serviceable boots for 2-lead, and 4 leads cables. 11 mm boots work nice on this type of Canare cable.
  • awe-d-o-file
    awe-d-o-file Posts: 146
    of buying "bi-wire" from "Monoprice"............nyuk nyuk nyuk
    ET
    System: MF Trivista SACD > Placette passive> CJ passive horizontal bi-amp> MF 2500A(LF) MF2100(HF) > 1.2TL's
    Other: Speltz silver Eichmann IC's & speaker wire, Econotweaks Detail Magnifiers, PS Audio P-300(source), R. Gray 600, Al Sekala's AC R/C filters, R. Gray HT PC's, Oyaide R-1's,WPC-Z , M-1, Herbie's & DIY Isolation
    Room: Qty 7 - 4' tall 18" diam. bass traps, Qty 4 - 4' X 2' X 4" panels. All DIY - man my wife is tolerant!
  • socaljeeper
    socaljeeper Posts: 15
    So if I want to set up bi-wiring to my front speakers, should I run the wires from my psw505 to my rti a1 speakers or from the receiver? do you run both the positive wires from the same output, to different inputs?
  • BjornB17
    BjornB17 Posts: 752
    I believe you have to place two separate orders for that to work.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • vonnie123
    from your receiver or amp. twist both positives together and both negatives together and connect them at the receiver/amp, then on the speaker side, one positve and one negative to each respective terminals set (2 sets per speaker).
  • Murray1
    Murray1 Posts: 193
    edited January 2010
    Help a color blind guy out. Looks like I am seeing red,pink,white,&grey or clear inside canare insulation. Simple question. What color wire goes to what binding post. Speakers have 4 binding posts. Two blacks and 2 reds. Need to know what color wire goes to what binding post. Thanks
  • Murray1
    Murray1 Posts: 193
    edited January 2010
    sorry. thought I was creating a new thread.
