Stop that rattling!
rallyshark
rallyshark Posts: 417
I thought I would share my new year's project with you guys:D I have hardwood floors, so the micro pro's were rattling everything. It was to the point where is wasn't "cool" anymore,lol! I've seen the subdude out there and heard a lot of positive feed back, so I figured I would see what I could build with all the junk I have laying around. I literally had everything to build it, so all it cost me was a little time, so I figured why the hell not... It is basically composed of layers of MDF, rubberized foam, and dynamat with low profile rubber feet on the bottom.
I routed out the top of it where the bottom sub would sit so that the feet fit perfectly and wouldn't be able to "walk". The top sub has automotive grade two sided black trim adhesive under the feet to keep it safely in place. It probably took me longer to make since my tool selection is limited. I'm very happy with the end result:) The bass is cleaner and tighter, with MUCH less rattling now! What do you guys think? I'm proud of myself, haha!
Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car?
Post edited by rallyshark on
  • thsmith
    thsmith Posts: 6,082
    edited January 2010
    Nice job ! Probably better than a subdude. Have you eq'ed your duals ?
  • rallyshark
    edited January 2010
    Thanks! EQ'd? What exactly are talking about? Do you mean Xover/levels etc? If so, then some, but not done yet. I just finished today. I haven't run audyssey yet, or really tweaked it, but it's pretty close I think.
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
  • superjunior
    superjunior Posts: 1,632
    edited January 2010
    nice job!
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2010
    Nothing like a home made tweak to fix a problem. Things rattling from the sub are one of the hardest room acoustic fixes.
  • dabo
    dabo Posts: 9
    edited January 2010
    you audioholics will stop at nothing... lol
    nice job!
    give us a review on the duel pro1000's when tweaked
  • rallyshark
    edited January 2010
    dabo wrote: »
    nice job!
    I will definitely give a review after I FINALLY get them set up the way I like. I've had them a few weeks, but am slowly taking steps to get them properly integrated. I can tell you that they are definitely different from what I had, so the combination of settings and letting my ears adjust to the different type of bass has taken a little time:)
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
  • dabo
    dabo Posts: 9
    edited January 2010
    Just received a pro3000 from Polkdirect and still playing with the settings.
    I figured with the weight of this thing and the rubber feet,
    this ain't going nowhere, but it once it started pounding, it
    was dancing all over the tile floor. I put some small rubber cups
    (I found at Home Depot) under the feet and seemed to alleviate
    the problem. very satified with the bass, no more boom, just very tight,
    accurate, fast and clean, excellent music SQ, blends nice with my M7's
  • rallyshark
    edited January 2010
    Congrats! That's a nice sub, I know I'm loving my 1ks. Are you having the same experience I am, as in a "different" kind of bass? Those things seem to "transfer" the low notes across the room quite well.
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
  • dabo
    dabo Posts: 9
    edited January 2010
    rallyshark wrote: »
    this is my first real sub, I upgraded from a 10yr old Yamaha which was a toy
    compared to the microPRO. I watched Swordfish on BD and the microPRO blew
    me away and with music, from jazz to the 1812 overture, very impressed
  • rallyshark
    edited January 2010
    Give it some time to break in, and it will likely get even better. Mine are sounding better every time I use them:) I've already started turning them down a little at a time as they start break in. I down 1.0db from where I started when they were new.
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    Great work, looks fantastic Rallyshark.
  • rallyshark
    edited January 2010
    Thanks doro! That means a lot to me coming from a polkie of your stature:)
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
  • dorokusai
    edited January 2010
    I'm actually a hunchback.
  • fossy
    fossy Posts: 1,378
    edited January 2010
    uummm .... well ..I'd crank er up anyways
    Very nice subs
  • rallyshark
    edited January 2010
    dorokusai wrote: »
    Hunch backs have stature, it's just a little different:D
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited January 2010
    rallyshark wrote: »
    Great job rally :cool:
    dabo wrote: »
    Nice set-up dabo and welcome to CP :)
    rallyshark wrote: »
    I can't wait to see pics of doro's SB50 array project, very intriguing :D
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • dabo
    dabo Posts: 9
    edited January 2010
    TECHNOKID wrote: »
    thankyou
