Pioneer 1019AH - M70, CS2, M40 small or large with Sub Plus?
kalmarx2
kalmarx2 Posts: 4
edited May 2010 in Speakers
Hi all,
I recently added the PSW10 to my setup with Monitor 70s, CS2 and Monitor 40 with Pioneer 1019AH.
Before the sub, I had all of the set to "large".
I have connected the PSW10 via RCA Y-cable and set the hz to max and volume at 50%. (I live in a condo I dont want the walls shaking)
The receiver has a subwoofer option for Yes or Plus (sends low frequencies to speakers).
Currently, I have all speakers set to large and I set the subwoofer option to Plus at 80hz. This sounds better to me than setting all speakers to Small with subwoofer set to Yes which sounds "boomy" to me.
I know the bottomline is I should use what sounds better to me, but is it better to have all the lows go through the sub instead?
Post edited by kalmarx2 on
  • eggie
    eggie Posts: 28
    edited January 2010
    i have the same speaker set up with the pioneer 1018 and the pro 600 sub, i have them all set to small and adjust the volume of the sub to my liking.
    edited January 2010
    kalmarx2 wrote: »
    Hi all,
    Yes!!
    There are no rules written in stone and too many factors to say one size fits all. Though a lot of people will tell you set everything to 'small'--if your ears say no...that's what counts!
    cnh
  • blt93932
    blt93932 Posts: 11
    edited May 2010
    How's that receiver driving those 70's?
  • inazsully
    inazsully Posts: 21
    edited May 2010
    It seems that there is quite a bit of woofer action available with the 70's to send all the heavy lifting to the subwoofer. I have my 70's set to large and my CS2 set to small and it sounds great with my 505 in the middle. I can't really tell much if any difference switching back and forth between small and large with my 70's.
