Onkyo SR707, RTi8 Bi-amp question
gorilla
I am trying to Bi-amp my front RTi8's using SR707. I can use Surround Back/Zone2 outputs from SR707 to bi-amp RTi8s. The SR707 manual specifies to connect Surround Back/Zone2 terminals to spekears Tweater(high) terminals while Front L/R terminals to be connected to spekars Woofer(low) terminals.
On my Polk RTi8 there is no markings on which terminals connect to tweeter Vs which terminals connect to Woofer. Can somebody help me with this? Is there a standard followed on RTi8's (like top two posts connect to tweeter while bottom two posts connect to Woofer OR viceversa ?)
TIA
TIA
Post edited by gorilla on
usually the top is for the highs and bottom posts for the lows, don't forget to remove the metal jumper platepanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
superjunior wrote: »usually the top is for the highs and bottom posts for the lows, don't forget to remove the metal jumper plate
Thanks.. Yep, I removed the metal plate. It is kind of odd that Polk does not label them neither in the manual not on the speakers -
Just a note - using an Onkyo in this config would be better off in a 2 channel mode, as the power supply is less taxed.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
