Onkyo SR707, RTi8 Bi-amp question
gorilla
gorilla Posts: 11
I am trying to Bi-amp my front RTi8's using SR707. I can use Surround Back/Zone2 outputs from SR707 to bi-amp RTi8s. The SR707 manual specifies to connect Surround Back/Zone2 terminals to spekears Tweater(high) terminals while Front L/R terminals to be connected to spekars Woofer(low) terminals.
On my Polk RTi8 there is no markings on which terminals connect to tweeter Vs which terminals connect to Woofer. Can somebody help me with this? Is there a standard followed on RTi8's (like top two posts connect to tweeter while bottom two posts connect to Woofer OR viceversa ?)
TIA
Post edited by gorilla on
  • superjunior
    superjunior Posts: 1,632
    edited December 2009
    usually the top is for the highs and bottom posts for the lows, don't forget to remove the metal jumper plate
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • gorilla
    gorilla Posts: 11
    Thanks.. Yep, I removed the metal plate. It is kind of odd that Polk does not label them neither in the manual not on the speakers
  • Serendipity
    Serendipity Posts: 6,975
    Just a note - using an Onkyo in this config would be better off in a 2 channel mode, as the power supply is less taxed.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
