Vinyl rocks
Montoya
Montoya Posts: 506
edited December 2009 in 2 Channel Audio
The cleaning and all the tedious things about vinyl are so worth it vinyl rocks period above all other formats. Name some of your currently playing vinyl regular rotation the one you keep listening to over and over.
Currently
Donald Fagen - Morph the cat
Steve Miller Band best of 74-78
Robert Plant/Allison Krauss- Raising Sand
Post edited by Montoya on
  • Fongolio
    Fongolio Posts: 3,516
    Dire Straits - Brothers in Arms
    Pink Floyd - Any
    Robert Plant - Any
    Paul McCartney - Band on The Run
    - Venus and Mars
    Peter Gabriel - Any
    I have over 1300 LP's and the ones above get very regular play. Love Morph The Cat on vinyl. By the way, I have every Steely Dan and all three Donald Fagen on vinyl including the impossible to find Kamakiriad. Superb recordings.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • thsmith
    thsmith Posts: 6,082
    Anything Mark Knopfler, DIre Strait, Poco and some Chris Rea.
  • hearingimpared
    hearingimpared Posts: 21,136
    Fongolio wrote: »
    I want that soooo bad but can't seem to find it at a reasonable price.
  • erniejade
    erniejade Posts: 6,321
    Robert Plant/Allison Krauss- Raising Sand Amazing LP and sounds fanststic!!!!! Especially on the sda 1.2's.
    Check out ray lamontagne Trouble or Gossip In The Grain LP. One listen and it will be on your rotation.
    Dave Brubeck time out
  • skipf
    skipf Posts: 694
  • schwarcw
    schwarcw Posts: 7,360
    Almost anything that is remastered by MoFi is worth listening. Whether it's pop, jazz, classical or rock, it's all great stuff
    For all you new comers to vinyl, virgin vinyl sounds the best. You can tell it's virgin vinyl by holding it up to the light. If you can see through it, it's virgin vinyl.
    Carl
