Vinyl rocks
Montoya
The cleaning and all the tedious things about vinyl are so worth it vinyl rocks period above all other formats. Name some of your currently playing vinyl regular rotation the one you keep listening to over and over.
Currently
Donald Fagen - Morph the cat
Steve Miller Band best of 74-78
Robert Plant/Allison Krauss- Raising Sand
Currently
Post edited by Montoya on
Dire Straits - Brothers in Arms
Pink Floyd - Any
Robert Plant - Any
Paul McCartney - Band on The Run
- Venus and Mars
Peter Gabriel - Any
I have over 1300 LP's and the ones above get very regular play. Love Morph The Cat on vinyl. By the way, I have every Steely Dan and all three Donald Fagen on vinyl including the impossible to find Kamakiriad. Superb recordings.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Anything Mark Knopfler, DIre Strait, Poco and some Chris Rea.Speakers: SDA-1C (most all the goodies)
I want that soooo bad but can't seem to find it at a reasonable price. -
Robert Plant/Allison Krauss- Raising Sand Amazing LP and sounds fanststic!!!!! Especially on the sda 1.2's.
Check out ray lamontagne Trouble or Gossip In The Grain LP. One listen and it will be on your rotation.
Dave Brubeck time out -
Almost anything that is remastered by MoFi is worth listening. Whether it's pop, jazz, classical or rock, it's all great stuff
For all you new comers to vinyl, virgin vinyl sounds the best. You can tell it's virgin vinyl by holding it up to the light. If you can see through it, it's virgin vinyl.Carl
