Looking for some towers
I recently picked up a amp for my upcoming HT. My amp puts out 145wpc and I'm looking for a recommendation on speakers. I recently heard a pair of Definitive BP7706 http://www.definitivetech.com/Products/products.aspx?path=Floor-Standing%20Speakers&productid=BP7006
I liked them but can anyone recommend me a pair of Polk's that are similar?
Thanks,
Thanks,
Post edited by acmf74 on
With the built in subwoofers, I would say that the only thing that might be comparable would be the LSi15's or maybe the LSi25's? However, they are going to be a bit more expensive than the Def's. Maybe something along the lines of the RTiA9's or 7's? I'm sure someone will have better/more advice soon.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Need a little more info
Budget?
Music, HT, both?
Room size? -
Budget is around 1500 give or take
Mostly HT
15x20 -
Do you have a separate preamp to go with your amp or a receiver? Please list your gear.
Welcome to Club Polk.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
RTi A9's should fit the bill and can be had from Polk Direct for $899 plus shipping.
get the Monitor 70s from newegg for $160 bucks a piece.Onkyo 805, RtiA5s, Csi5, Rti6s
Eh... if he's got a $1500 budget, there's really no reason for him to settle with Monitors.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thanks all but I picked up a pair of LSi15's
Very excited. -
I second the lsi's the only thing with the 15's are the built in sub is not powered by its own power supply it relies on the power of your receiver. "as I know of" I would recommend the lsi 25's of the ML source.
http://www.martinlogan.com/products/sourceHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Very excited.
Congrats. Just realize that as well as a receiver, you will need a separate amplifier with at least 200wpc to get the best out of them.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
youre definitly set for speakers for a while, thats for sure. as long as your amp is 4 ohm stable, you're good to go. They will sound good now (give them time to break in though), and they will reward you down the road with any amplification upgrades you make down the road.
The only speakers I hear that I like as much or signiicantly better cost a **** ton more than the 15's, so I figure I'm gonna have them for a good long while.
good luck with emLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
+1, if your AVR isn't rated for 4 ohms, you won't have those 15's for long, lol. Either that or your AVR will go into protect mode and you may damage it or the speakers. If you have pre-outs on your AVR, get some external amplification and you will be in business. For now, be careful with the volume knob!!
-JeffHT Rig
Blu-Ray- 80 GB PS3
Nice choice with the LSi's. Congrats and welcome to the clubHome TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
thanks...my AVR is 4ohm stable. for now will will run them like this for awhile...eventually I will pair up another amp for these speakers.
is there a break-in period?? if so what are the procdeures?
thanks.. -
I'd love to audition the LSi series... but they don't have em at the local bestbuy/magnolia showroom. Are they leagues better than the RTiA series?My system:
Front: 2xPolk RT800 Floor speakers (Bi-wired) - SOLD
Center: Polk CSi5 - For Sale!
Receiver: Onkyo TX-SR806 THX-Ultra2 130W 7.1
Sub: Velodyne DPS-12 -
More different than anything.... RTiAs are forward, a little bright. LSis are more laid back, i would imagine better for music.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I see, the RT800s that I have are a bit neutral sounding, very comparable to my CSi5 center. If I could only sample the LSis... too bad you can't find a good deal on those. They never go on "sale" or "clearance".My system:
LSI-15s...good choice, especially for music...but you won't be that impressed with their 'musical' sound unless you do what cfrizz advises above. Those speakers will not sound as good as they can without a lot of POWER!
my avr is rated at 275wpc and is 4ohm stable...
I think I'm in the clear...:) -
Sounds like a beast of an AVR....
-JeffHT Rig
Blu-Ray- 80 GB PS3
What is the receiver, Sunfire?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
