making speakers in-wall...sort of
Jdubbs
I am thinking of getting VM20's for my front and center speakers. I have an LED Samsung with a slim wall mount and the tv is about 2 inches off the wall (LOOKS AWESOME!!!!!!). Anyway, I wanted to try to have a flat look when it came to the speakers but the custom B&W's were out of my budget lol.
With the VM 20's, I love their look but they are just under 6 inches off the wall with the wall including the bracket.
I was thinking of boxing out my drywall to recess the speakers a little bit. I was thinking of have the speakers about halfway in the wall so there would be 3 inches in and 3 inches out of the wall.
Does anyone know if this would be good/bad/indifferent on the sound quality?
50" Sony LCD
Denon 3805
Polk Audio RM 20 system
Polk Audio 12" sub
PS3
Wii
Harmony One
HT system #2
55" Samsung LED
Pioneer Elite VSX 23
Fronts, Center- Polk VM 20
Rears- Polk VM10
Sub - DSW Pro 600
Harmony 900
Denon 3805
Polk Audio 12" sub
PS3
Wii
Harmony One
HT system #2
55" Samsung LED
Rears- Polk VM10
Sub - DSW Pro 600
Harmony 900
Post edited by Jdubbs on
Not really sure to be honest. I guess it would depend if the VM20's have a rear port, then it may be an issue boxing them in like that. If they don't, then I wouldn't see a problem, not too familiar with them so I'll leave it to somebody with experience. Good luck.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
thanks for the response...they dont have any holes anywhere so I dont think it would be an issue but i'm a dumba$$ compared to some of you guys on here lol. i think they would look great but dont want to scarifice on the audio side. thanks again.50" Sony LCD
Denon 3805
Polk Audio 12" sub
PS3
Wii
Harmony One
HT system #2
55" Samsung LED
Rears- Polk VM10
Sub - DSW Pro 600
Harmony 900 -
Take a look at the link in post #6 of this thread. These are not VM's but a similar sized speaker, then you could ask mantis for details if you need some, he would probably be very helpful.
http://www.polkaudio.com/forums/showthread.php?p=1230477#post1230477 -
thanks for this, I will def contact him. It's an awesome install. thanks again.50" Sony LCD
Denon 3805
Polk Audio 12" sub
PS3
Wii
Harmony One
HT system #2
55" Samsung LED
Rears- Polk VM10
Sub - DSW Pro 600
Harmony 900
