making speakers in-wall...sort of
Jdubbs
Jdubbs Posts: 51
I am thinking of getting VM20's for my front and center speakers. I have an LED Samsung with a slim wall mount and the tv is about 2 inches off the wall (LOOKS AWESOME!!!!!!). Anyway, I wanted to try to have a flat look when it came to the speakers but the custom B&W's were out of my budget lol.
With the VM 20's, I love their look but they are just under 6 inches off the wall with the wall including the bracket.
I was thinking of boxing out my drywall to recess the speakers a little bit. I was thinking of have the speakers about halfway in the wall so there would be 3 inches in and 3 inches out of the wall.
Does anyone know if this would be good/bad/indifferent on the sound quality?
50" Sony LCD
Denon 3805
Polk Audio RM 20 system
Polk Audio 12" sub
PS3
Wii
Harmony One
HT system #2
55" Samsung LED
Pioneer Elite VSX 23
Fronts, Center- Polk VM 20
Rears- Polk VM10
Sub - DSW Pro 600
Harmony 900
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited December 2009
    Not really sure to be honest. I guess it would depend if the VM20's have a rear port, then it may be an issue boxing them in like that. If they don't, then I wouldn't see a problem, not too familiar with them so I'll leave it to somebody with experience. Good luck.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Jdubbs
    Jdubbs Posts: 51
    thanks for the response...they dont have any holes anywhere so I dont think it would be an issue but i'm a dumba$$ compared to some of you guys on here lol. i think they would look great but dont want to scarifice on the audio side. thanks again.
    50" Sony LCD
    Denon 3805
    Polk Audio 12" sub
    PS3
    Wii
    Harmony One
    HT system #2
    55" Samsung LED
    Rears- Polk VM10
    Sub - DSW Pro 600
    Harmony 900
  • apphd
    apphd Posts: 1,514
    Take a look at the link in post #6 of this thread. These are not VM's but a similar sized speaker, then you could ask mantis for details if you need some, he would probably be very helpful.
    http://www.polkaudio.com/forums/showthread.php?p=1230477#post1230477
  • Jdubbs
    Jdubbs Posts: 51
    thanks for this, I will def contact him. It's an awesome install. thanks again.
    50" Sony LCD
    Denon 3805
    Polk Audio 12" sub
    PS3
    Wii
    Harmony One
    HT system #2
    55" Samsung LED
    Rears- Polk VM10
    Sub - DSW Pro 600
    Harmony 900
