New RTi A9 pic
Nice set up. Wish I had a larger room like yours.:)Receiver-Onkyo TX-NR 3010
Amp-Emotiva XPA-5
Front-RTi A9's
Front Hieght RTi A1's
Center-CSi A6
Surround-RTi A5's
Rear-RTi A3's
Subs-Velodyne DLS-4000R x2
TV-65" Samsung LNF659000 UHD LED -
man u really need to change the couches
nice setup, the TV is little bit too high. -
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
A goldish brown on the walls with the brick painted dark and maybe some couch covers and that room would be really nice! The speaker system is already there.
TV: Samsung LN40A550
Mains: Polk Monitor 70's
Center: Polk CS2
Surrounds: Polk OWM3's
Receiver: Onkyo TX sr705
BDP: Sony S350
Subs: Velodyne VRP1200 and VRP1000
Monster Power Conditioner EP IR 2450 -
Where should he put it, in front of his fireplace?:rolleyes: -
i didn't say that he is not challenged with the setup. -
Well, at the risk of hacking off a few folks, I think the 9's are a better speaker. The bass and mids are simply stronger. Are they strong enough to justify the cost difference?? Depends on your individual circumstances. Also keep in mind that you may have a shot at running your 7's from your AVR, and the 9's really do need a reasonable amp to make them sing. All I can say is when I added the 9's as fronts, plugged them into a 200WPC amp, and stuck the 7's in as surrounds.... it all added up to a very significant improvement in my system.
Nice answer, nice setup, just well done all around!:) -
Very nice system. Seems well balanced. Beautiful clean nice room man. Nice job.Dan
yes, it is an option. I have been thinking about doing that very thing. Thanks.
Put your room in the showcase...btw my room is about the same color as yours.
Center: Polk CS2
BDP: Sony S350
All good ideas for sure.Shoot the jumper.....................BALLIN.............!!!!!
It was there. Just needed updating. Done now. (same pics as on this thread.)
