7.2 hts
tyheeguy
tyheeguy Posts: 14
so here we go....sony str da5400ES (plan on purchasing all ES series components) polk rti a9 @ 4 (fronts), csi a6 (center), rti a3 @ 2 (rear surrounds) and dsw pro 600 @ 2 (powered subwoofers) for my thumpers.
What i am wondering is this: to much speaker for the reciever i have or do i need to amp it up. also if i do need to amp it up what is a good / higher end 7 chammel amp. i am new to this audio stuff and really don't have a clue as to what i need to do.......:confused:...any help or info wuold be greatly appreciated. not into starting over because some components and speakers are already purcahsed.
Be good.....and if you can't be good, be great.........and if you can't be great, well,......i'll give you lessons.
Post edited by tyheeguy on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited December 2009
    I think you need to go with a external amp. I do not think that sony is going to like a 4 ohm load. What is your left over budget from your setup? Also yes why do you have 4 fronts? you should only have 2 a center and a sub not 4 towers.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • concealer404
    concealer404 Posts: 7,440
    Why do you have four fronts?
  • tyheeguy
    tyheeguy Posts: 14
    it is a 7.1 reciever, right A & B, left A & B i guess you can call the b channel speakers part of the surrounds / sides.
  • concealer404
    tyheeguy wrote: »
    A/B is for a second pair of speakers to be used by themselves...
  • bigaudiofanatic
    Correct concealer.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • concealer404
    Anyways... that's not correct 7.2 placement.....
    You should have two fronts, a center, surround left, surround right, surround back left, surround back right, and your two subs.
  • tyheeguy
    tyheeguy Posts: 14
    so back to the original question, specs for the reciver says 7 X 120 per channel = 840 watts total. would adding a amp make the reciever "work" less hard. as far as the 4 ohm load goes, none of the speakers will be hooked to create a 4 ohm load.
  • concealer404
    tyheeguy wrote: »
    Yeah, adding an amp would leave less work to the receiver, as well as give more and a higher quality power to the speakers.
    Is it truly 120wpc with all 7 channels driven?
  • superjunior
    superjunior Posts: 1,632
    tyheeguy wrote: »
    none of the speakers you are refering to are 4 ohm, they're 8 so the sony could drive them. however using an amp for your front stage will really bring them to life and free up some juice for your surrounds.
    jr
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • tyheeguy
    tyheeguy Posts: 14
    well, manufacturer specs say 120 x 7 ,so thats what i am referencing, as i have no way of reffering to other specs. so back to the amp ?, how many channel amp would be a good choice, and which one to would be compatible with my reciever. the reciever is pushing 120 per channel now, so shouldn't that be sufficient watts. would a amp really make that much of a difference? i am a rookie to all this stuff
  • superjunior
    tyheeguy wrote: »
    it really depends on your budget. the more power you give the a9s the better they sound. If anything I would at least get a 2 channal amp for them. a 3 channal amp for the a9s and a6 would sound even better. I'm running an emotiva xpa-3 that sends 200wpc into the a9s and a6 and my surrounds are powered by the receiver. I'm pretty happy with the set up. theres lots of different amps out there, adcom, parasound, emotiva, rotel, krell and on and on. your best bet if you can is to demo a few different brands and see (hear) what sounds best to you. welcome to cp btw!
    jr
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
