Running RTi A9's with Sansui G-7500
tugzy
tugzy Posts: 46
edited March 2014 in Speakers
I just got my RTI A9s a few days ago and already love them...right now im running them with a Sansui G-7500 for 2 ch music and Pioneer VSX01-TXH for 7.1 HT.
Question with the Sansui for 2ch music: any benefit of i Bi amp the speakers by connecting the highs to Speaker A and the lows to Speaker B? Is that not a true Bi amp? Or should I Bi-wire??
Thanks for your help
Polk RTi A9, Polk CSi A6
Paradigm Sub, Side, Rears
Emotiva XPA-2, Pioneer Elite VSX-01TXH A/V 7.1
LG BD390C BR, LG 60PG60 Plasma
Hotaudio DAC Extacy
XPA-2/RTiA9 in Action
http://www.youtube.com/watch?v=-rtxxb2RIws
http://www.youtube.com/watch?v=bgWk-fCAooo
--vintage--
Sansui G-7500 Pure Power DC receiver
Sansui SP-X8000 4way/6driver speaker
Sansui SR-535 Turntable
Cerwin Vega AT-12 < Bud Beer
Post edited by tugzy on
  • ls7z06
    ls7z06 Posts: 95
    edited December 2009
    How much power does your current amp deliver?
    I, as well as many others here run my RTi A9's on an Emo XPA-3 delivering 200wpc. I have done nothing except run single wires to the speakers and they sound fantastic.
  • jaygax
    jaygax Posts: 153
    edited March 2014
    beautiful setup man!
    pitdogg2 Posts: 26,926
    edited March 2014
    tugzy wrote: »
    Forget all about this...^^^^^^Bi amping involves active crossovers and multi amps ..you have neither. You could bi-wire but really I see no gain with what you have. Make a better jumper out of better cable instead of the brass plate Polk used that may get you a touch better sound or just make you feel better, but many here do make a better jumper. If you use banana's use spades for jumper if you use spades make jumpers with banana plugs...
    edited March 2014
    I can't think of "any" vintage Sansui that can properly handle power to a set of Polk A9s. You REALLY need a power amp. Preferably one that can supply a "minimum" of 250 watts x 2 @ 8 ohms and preferably 350 watts x 2 or more @ 8 ohms. Those Rti-A9s need a LOT of power to shine!
    Your G-7500 is not even in the ballpark at 90 watts x 2 @ 8 ohms.
    cnh
  • 4xoddic
    4xoddic Posts: 372
    edited March 2014
    cnh wrote: »
    You REALLY need a power amp. Preferably one that can supply a "minimum" of 350 watts x 2 or more @ 8 ohms. Those Rti-A9s need a LOT of power to shine!
    cnh
    The polkie running 350/wpc noticed improvement gains as he stepped up with each more powerful amplifier.
    Two of us have jumped to > 700 wpc & are pleased with the results. Unsure of why Polk rated the a9s' power handling so conservatively (500 wpc). I usually run mine @ <90dB in an 11'X19' room. But have been known to raise the dB to fill the house with music.
    As for a reference point:
    Your VSX01-TXH appears to have Pioneer's new "type of Class D amplifier powerful enough for professional use. The result was the Direct Energy HD amplifier"
    VSX01-TXH: 110 Watts x 7 (20Hz - 20kHz, 8 ohms)
    I previously used my Pioneer Elite SC07's B&O ICE amps to drive my RTiA9s with 140 wpc. They sounded fatiguing, so I scaled back the highest frequencies. When listening to hours of 2 Channel music, they still were fatiguing. Using the front preouts to a Class EEE "amplifier powerful enough for professional use," erased that fatigue (a cause of weariness; slow ordeal; exertion: the fatigue of listening to underpowered RTiA9s for many hours).
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited March 2014
    You guys do realize the OP asked this question in 2009, right?
    Carry on,
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited March 2014
    Haha! Can I answer anyway :p
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
