Questions About HT
bigaudiofanatic
A few questions about home theater.
On older receivers "like 6 years ago" your only option for audio was rca red and white cables. How did anything get true surround sound that way?
New tv's are wide screen but why are our BR movies still having black lines? Why would they need to be stretched to be full screen?
Why do some BR's look better than others even though all were put out around the same time?
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
Post edited by bigaudiofanatic on
i think for the 2nd question, because widescreen movies are actually 2.35:1 ratio. Normal widescreen TVs are usually of 16:9 ratio. Why? I dont know...Onkyo 805, RtiA5s, Csi5, Rti6s
bigaudiofanatic wrote: »A few questions about home theater.
True surround sound???? Are you infering that only HDMI supports surround sound?
The DVD player decodes the audio on the DVD and sends it out the analog (RCA) ports. There are two for the front (L/R), two for the rear surround (L/R), and one for the center. They attach to the five corresponding ports on the AVR and you have "true surround sound". There is also a sub output for those that need it.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
For some reason it is putting a big space in here and I can't figure out why, but below is the list of aspect ratios with uses. More info at: http://en.wikipedia.org/wiki/Aspect_ratio_(image)
Taken from Wikipedia.
<table Border=1>
<tbody><tr>
<th>Aspect ratio</th>
<th>Description</th>
</tr>
<tr>
<th>1.33:1</th>
<td>35 mm original silent film ratio, commonly known in TV and <a href="/wiki/Video" title="Video">video</a> as 4:3. Also standard ratio for <a href="/wiki/MPEG-2" title="MPEG-2">MPEG-2</a> video compression. This format is still used in most personal video cameras today. It is the standard 16 mm and <a href="/wiki/Super_35" title="Super 35">Super 35mm</a> ratio.</td>
</tr>
<tr>
<th>1.37:1</th>
<td>35 mm full-screen sound film image, nearly universal in movies between 1932 and 1953. Officially adopted as the <a href="/wiki/Academy_ratio" title="Academy ratio">Academy ratio</a> in 1932 by <a href="/wiki/AMPAS" title="AMPAS" class="mw-redirect">AMPAS</a>. Rarely used in theatrical context nowadays, but occasionally used for other context.</td>
</tr>
<tr>
<th>1.43:1</th>
<td><a href="/wiki/IMAX" title="IMAX">IMAX</a> format. Imax productions use 70 mm wide film (the same as used for 70 mm feature films), but the film runs through the camera and projector sideways. This allows for a physically larger area for each image.</td>
</tr>
<tr>
<th>1.50:1</th>
<td>The aspect ratio of 35 mm film used for still photography when 8 perforations are exposed. Usually called 3:2. Also the native aspect ratio of VistaVision.</td>
</tr>
<tr>
<th>1.56:1</th>
<td>Widescreen aspect ratio 14:9. Often used in shooting commercials etc. as a compromise format between 4:3 (12:9) and 16:9, especially when the output will be used in both standard TV and widescreen. When converted to a 16:9 frame, there is slight <a href="/wiki/Pillarbox" title="Pillarbox">pillarboxing</a>, while conversion to 4:3 creates slight <a href="/wiki/Letterbox" title="Letterbox">letterboxing</a>.</td>
</tr>
<tr>
<th>1.66:1</th>
<td>35 mm Originally a flat ratio invented by <a href="/wiki/Paramount_Pictures" title="Paramount Pictures">Paramount Pictures</a>, now a standard among several European countries; native Super 16 mm frame ratio. (5:3, sometimes expressed more accurately as "1.67".)</td>
</tr>
<tr>
<th>1.75:1</th>
<td>Early 35 mm widescreen ratio, primarily used by MGM and Warner Bros. between 1953 and 1955, and since abandoned.</td>
</tr>
<tr>
<th>1.78:1</th>
<td>Video widescreen standard (16:9), used in <a href="/wiki/High-definition_television" title="High-definition television">high-definition television</a>, one of three ratios specified for <a href="/wiki/MPEG-2" title="MPEG-2">MPEG-2</a> video compression. Also used in some personal video cameras.</td>
</tr>
<tr>
<th>1.85:1</th>
<td>35 mm US and UK widescreen standard for theatrical film. Introduced by <a href="/wiki/Universal_Pictures" title="Universal Pictures" class="mw-redirect">Universal Pictures</a> in May, 1953. Projects approximately 3 <a href="/wiki/Film_perforations" title="Film perforations">perforations</a> ("perfs") of image space per 4 perf frame; films can be shot in <a href="/wiki/Negative_pulldown" title="Negative pulldown">3-perf</a> to save cost of film stock.</td>
</tr>
<tr>
<th>2.00:1</th>
<td>Original <a href="/w/index.php?title=SuperScope&action=edit&redlink=1" class="new" title="SuperScope (page does not exist)">SuperScope</a> ratio, also used in <a href="/wiki/Univisium" title="Univisium">Univisium</a>. Used as a flat ratio for some American studios in the 1950s, abandoned in the 1960s, but recently popularized by the <a href="/wiki/Red_Digital_Cinema_Camera_Company" title="Red Digital Cinema Camera Company">Red One</a> camera system.</td>
</tr>
<tr>
<th>2.20:1</th>
<td>70 mm standard. Originally developed for <a href="/wiki/Todd-AO" title="Todd-AO">Todd-AO</a> in the 1950s. 2.21:1 is specified for <a href="/wiki/MPEG-2" title="MPEG-2">MPEG-2</a> but not used.</td>
</tr>
<tr>
<th>2.35:1</th>
<td>35 mm anamorphic prior to 1970, used by <a href="/wiki/CinemaScope" title="CinemaScope">CinemaScope</a> ("'Scope") and early <a href="/wiki/Panavision" title="Panavision">Panavision</a>. The anamorphic standard has subtly changed so that modern anamorphic productions are actually 2.39,<sup id="cite_ref-anamorphic_0-2" class="reference"><a href="#cite_note-anamorphic-0"><span>[</span>1<span>]</span></a></sup> but often referred to as 2.35 anyway, due to old convention. <i>(Note that anamorphic refers to the compression of the image on film to maximize an area slightly taller than standard <a href="/wiki/Negative_pulldown" title="Negative pulldown">4-perf</a> <a href="/wiki/Academy_of_Motion_Picture_Arts_and_Sciences" title="Academy of Motion Picture Arts and Sciences">Academy</a> aperture, but presents the widest of aspect ratios.)</i></td>
</tr>
<tr>
<th>2.39:1</th>
<td>35 mm anamorphic from 1970 onwards. Sometimes rounded up to 2.40:1<sup id="cite_ref-anamorphic_0-3" class="reference"><a href="#cite_note-anamorphic-0"><span>[</span>1<span>]</span></a></sup> Often commercially branded as <a href="/wiki/Panavision" title="Panavision">Panavision</a> format or <a href="/wiki/CinemaScope" title="CinemaScope">'Scope</a>.</td>
</tr>
<tr>
<th>2.55:1</th>
<td>Original aspect ratio of <a href="/wiki/CinemaScope" title="CinemaScope">CinemaScope</a> before optical sound was added to the film in 1954. This was also the aspect ratio of <a href="/wiki/CinemaScope_55" title="CinemaScope 55">CinemaScope 55</a>.</td>
</tr>
<tr>
<th>2.59:1</th>
<td><a href="/wiki/Cinerama" title="Cinerama">Cinerama</a> at full height (three specially captured 35 mm images projected side-by-side into one composite widescreen image).</td>
</tr>
<tr>
<th>2.66:1</th>
<td>Full frame output from Super 16 mm negative when an anamorphic lens system has been used. Effectively, an image that is of the ratio 2.66:1 is squashed onto the native 15:9 aspect ratio of a Super 16 mm negative.</td>
</tr>
<tr>
<th>2.76:1</th>
<td><a href="/wiki/Ultra_Panavision_70" title="Ultra Panavision 70">MGM Camera 65</a> (65 mm with 1.25x anamorphic squeeze). Used only on a handful of films between 1956 and 1964, such as <i><a href="/wiki/Ben-Hur_%281959_film%29" title="Ben-Hur (1959 film)">Ben-Hur (1959)</a></i>.</td>
</tr>
<tr>
<th>4.00:1</th>
<td>Rare use of <a href="/wiki/Polyvision" title="Polyvision">Polyvision</a>, three 35 mm 1.33 images projected side by side. First used on <a href="/wiki/Abel_Gance" title="Abel Gance">Abel Gance</a>'s <i><a href="/wiki/Napol%C3%A9on_%281927_film%29" title="Napol -
Check out AVS for more information than you'd ever want/need on the subject, as well as rankings:
http://www.avsforum.com/avs-vb/showthread.php?t=11683422007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
Great info by the way BeRad. I'm printing that off for future reference...2007 Club Polk Football Pool Champ
No this is way before hdmi, before fiber optic before coaxial. When all it was was two rca's going from like a vcr or dvd player to a receiver. I am not referring to the 6 inputs you have now.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Ya that is what I am trying to figure out. Why did we change our tv format if it is not going to fill the entire screen. I understand there are many different formats. By now they should be standard 16:9HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
That was alot longer than 6 years ago my friend.HT SYSTEM-
lsi 9's -
LOL ya now that I think about it shoot it was more like 10 years or longer than that actually. My faultHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
bigaudiofanatic wrote: »LOL ya now that I think about it shoot it was more like 10 years or longer than that actually. My fault
Memory...the first to go. No sweat,I can't friggin' remember my own phone number at times.HT SYSTEM-
lsi 9's -
LOL I hope you remember it more than you forget it.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
bigaudiofanatic wrote: »No this is way before hdmi, before fiber optic before coaxial. When all it was was two rca's going from like a vcr or dvd player to a receiver. I am not referring to the 6 inputs you have now.
Then you are not talking about surround sound. You are talking about stereo. DVD has supported 5.1 sound from the beginning. I guess it is possible some manufacturers made dirt cheap models with only 2 outputs. I do not think VCR ever supported surround sound.Lumin X1 file player, Westminster Labs interconnect cable
I am talking about surround sound. My neighbor has a older sony receiver it is a 5.1 dolby one. The only connections you can make on the back were rcas red and white that was it.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
I think he is saying on receivers, there are oonly two inputs... Not outputs.
I have an old HK receiver that is like this; it supports optical as well, but the analogue input is just RCA cables... EDIT: And my HK is a 5.1 capable receiver from that 2 cable source, just to clarify.
How does 5 channels translate across from a two cable source?
I think it's magic.
? Harmon Kardon AVR 55 (dead; replacing with Onkyo TX NR-616)
? Polk RTA 11TL's (FR and FL)
? Polk TSi200's (RR and RL)
? Polk CS10 (Center)
? Polk PSW-350
? Grado SR-60i Headphones
? Fii0 E5 headphone amp
? iPod touch (8 gig)
? iPod Classic (80 gig)
? Mac Mini (as media server)
? xbox 360 -
Yes that is what I was asking. How? lolHT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
I bet it's just splitting signal, and not outputting exactly what was really on the DVD.
Much like you CAN play 2-channel music signals through all channels of a 7.1 setup if you wanted to. But that doesn't mean it's 7.1 surround.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Got ya that is what I was trying to figure out. So it was never really real surround sound.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
bigaudiofanatic wrote: »Got ya that is what I was trying to figure out. So it was never really real surround sound.
That's what i think... of course, i COULD be wrong, since i wasn't big into HT back then, but unless it's a digital signal, you're going to need one lead for each output.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
As for the other questions.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
The second question was answered...
The third question, was kindof answered.
My spin on it: For the same reason some cds sound better than others.
bigaudiofanatic wrote: »Ya that is what I am trying to figure out. Why did we change our tv format if it is not going to fill the entire screen. I understand there are many different formats. By now they should be standard 16:9
the only explanation (at least to me) is that most of the cable broadcasted channels are done in 4:3, and if a screen has the ratio of 2.35:1, we'd now have "vertical bars" on both sides that would take up to like half or even more than half of the TV size...Onkyo 805, RtiA5s, Csi5, Rti6s -
concealer404 wrote: »The second question was answered...
Ya but a movie like public enemies looked snowy while another movie like star trek, batman the dark night, and xmen wolverine all look fantastic. They where all in BR as well.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Just how well they were transferred. Some are done better than others. Different people doing the process using different programs and electronics etc etgc etc.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
If there are just two inputs L/R...then it's 2 channel. Period.
Now, if there are 6 inputs(L,R,C,SR,SL and sub out)...that is, indeed, surround sound. Probably a Dolby Pro Logic (you guys remember that??)
Here is how it worked. Now, you all know that there is, at some point, digital to analog conversion. Back in the day, the receivers were 'digital ready' or whatever because they had the analog inputs for all the channels. The actual decoding was done by the DVD player (if it was equiped with the decoder) and you hooked up all the analog channels from the DVD player to the receiver. As time went by, all receivers had DD/DTS decoders. I did this for a long time.
Now, yes, you can take any 2 channel source, put it into the stereo inputs and get Dolby Pro Logic surround. Geeze, don't you guys know anything about Dolby Digital?? We used to have HUGE debates about this...and DTS and so forth.
Yes but before that all there was was just left and right even on receivers that say Dolby digital and surround sound. When I was younger I saw a lot of them.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
This link can explain the anamorphic ratio (2.35:1), black bars and all that goodness:
http://www.thedigitalbits.com/articles/anamorphic/aspectratios/widescreenorama.html -
bigaudiofanatic wrote: »Yes but before that all there was was just left and right even on receivers that say Dolby digital and surround sound. When I was younger I saw a lot of them.
Okay, if there were only L/R inputs...you didn't have Dolby Digital. Dolby Digital 5.1 meant there is 6 discrete channels. Decoded digitally. Again, this could be done by the receiver or the DVD player. Now, your receiver would still have 2ch inputs for TV/VCR/Tuna...just as they do now.
If it was a L/R (2 channel) input (TV/VCR...etc)....yes, Dolby Surround or Dolby Pro Logic. It used an analog algorithim to extract the rear/center channels. Surround: Yes. Dolby Digital: No.
Thanks zero that is a lot easier to understand.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
Picture aspect and the sound have nothing to do with each other....which were you asking about??
I was asking about both the audio in an older sense like 10 years ago the aspect is about todays stuff.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
