Best Bi-wire Nordost?
jparker82
jparker82 Posts: 54
Running Nordost Blue Heaven rev2 on my LSI 25's and LSI Center. Want to upgrade wires on my LSI 9's and 7's was wondering if there is another good biwire out there that isn't as expensive.
Onkyo Tx Nr 5007
Integra NAS 2.3 audio serv
Intergra DHS 8.8 HD-DVD
Integra NVS 7.7 Home Theater Media Compt
Anthem MCA 20
Integra 70.1 9 channel amp
OPPO 93 BLU RAY
Monster HDP-2400 power cond
Panamax M5300 PM
Monster HtS-2600 Power cond
Samsung 8000 series e64 plasma
Polk LSI 25
Polk LSI center
Polk LSI 9
Polk LSI 7
Polk LSIM702 fx
Boston Acoustic in ceil #'s ???
Definitive tech sub
Nordost Blue Heaven Rev2 BI wire(great cords)
2 other systems master and pool area
Post edited by jparker82 on
    F1nut Posts: 51,926
    edited December 2009
    Here's a tip.......forget about bi-wiring. Instead use regular speaker cable, remove the stock jumpers and replace with high quality jumper wire.
  • DMara
    DMara Posts: 1,434
    F1nut, I am thinking about replacing my lsi15s' stock jumpers. Would you please share your thought on what type / name brand of jumper wire should I acquire? Are there any specific discussion thread involving this task that I should read before doing so?
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
    F1nut Posts: 51,926
    Any high quality wire is better than the stock jumpers. I prefer MIT's jumpers.
    I'm sure there is, but I don't recall a specific one off the top of my head.
  • jparker82
    jparker82 Posts: 54
    Thanks for the info. I will try a couple sets.
    Onkyo Tx Nr 5007
    Anthem MCA 20
    OPPO 93 BLU RAY
    Panamax M5300 PM
    Polk LSI 25
    Polk LSI center
    Polk LSI 9
    Polk LSI 7
    Polk LSIM702 fx
    Definitive tech sub
