Best Bi-wire Nordost?
jparker82
Running Nordost Blue Heaven rev2 on my LSI 25's and LSI Center. Want to upgrade wires on my LSI 9's and 7's was wondering if there is another good biwire out there that isn't as expensive.
Onkyo Tx Nr 5007
Integra NAS 2.3 audio serv
Intergra DHS 8.8 HD-DVD
Integra NVS 7.7 Home Theater Media Compt
Anthem MCA 20
Integra 70.1 9 channel amp
OPPO 93 BLU RAY
Monster HDP-2400 power cond
Panamax M5300 PM
Monster HtS-2600 Power cond
Samsung 8000 series e64 plasma
Polk LSI 25
Polk LSI center
Polk LSI 9
Polk LSI 7
Polk LSIM702 fx
Boston Acoustic in ceil #'s ???
Definitive tech sub
Nordost Blue Heaven Rev2 BI wire(great cords)
2 other systems master and pool area
Anthem MCA 20
OPPO 93 BLU RAY
Panamax M5300 PM
Polk LSI 25
Polk LSI center
Polk LSI 9
Polk LSI 7
Polk LSIM702 fx
Definitive tech sub
Here's a tip.......forget about bi-wiring. Instead use regular speaker cable, remove the stock jumpers and replace with high quality jumper wire.
F1nut, I am thinking about replacing my lsi15s' stock jumpers. Would you please share your thought on what type / name brand of jumper wire should I acquire? Are there any specific discussion thread involving this task that I should read before doing so?Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
Any high quality wire is better than the stock jumpers. I prefer MIT's jumpers.Are there any specific discussion thread involving this task that I should read before doing so?
I'm sure there is, but I don't recall a specific one off the top of my head. -
Thanks for the info. I will try a couple sets.Onkyo Tx Nr 5007
Anthem MCA 20
OPPO 93 BLU RAY
Panamax M5300 PM
Polk LSI 25
Polk LSI center
Polk LSI 9
Polk LSI 7
Polk LSIM702 fx
Definitive tech sub
