Integrated amps..
TroyD
TroyD Posts: 13,124
edited December 2009 in 2 Channel Audio
Man, I've been dicking with the rig quite a bit lately. Swapping out the Quads for the Vandys....moving in the Classe instead of the Heaths etc etc...
Perhaps I'm going soft but I just would like to simplify. The whole stack of gear (no remote, either) is such a whip...yada yada yada. I'm this (holding my thumb and forefinger very close) close to selling all the separates and searching out a high tone integrated.
The more I think, the more sense it makes.....plug and play, baby. Plug and play.
Am I losing my marbles or what?
BDT
Post edited by TroyD on
«13
  • hearingimpared
    hearingimpared Posts: 21,136
    No you are not losing your marbles. Perhaps a Musical Fidelity Trivista 300 or kw integrated is in your future.
  • TroyD
    TroyD Posts: 13,124
    anyone need some one-off tube monos, custom tube phono stage and a Melos SHA-1??
    I LOVE my gear. LOVE it....but, man, I want less clutter. More remote.
    BDT
  • Systems
    Systems Posts: 14,873
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    I think you should go stick your head in the toilet and flush it, the swirling you hear is your brain hitting reset. Your rig is fine. If you still want to do it then rock on with your bad self but I would recommend you leave the Quad rig when the Amazings are up you can have some fun with other stuff.
    I am not buying the "simplify" mantra, flavor of the month agenda. There are fine integrated units but "simplify" isn't why I would own one, in fact I did own a few.
    RT1
  • steveinaz
    steveinaz Posts: 19,545
    There is something to be said about "simple"--less noise. I have debated the idea of a high-tone integrated from time-to-time, but I have a large room, and I like LARGE sound. It's hard to find the combination that would interest me in an integrated.
    My system right now has 1 set of RCA IC's---that's it; from the preamp to the amp. Those are only .5mtr. I haven't simplified for any particular reason, it just ended up that way. I have 3 sources; Direct TV HD STB (via toslink), Panasonic BluRay (via coax), and y CEC CDP (via coax). Using the Benchmark as my preamp as well as DAC allowed me to get 35lbs of electronics OUT of my system--that has to be a good thing.
  • vc69
    vc69 Posts: 2,500
    Steve,
    Are you seriously using coax for your BD player audio connect? :confused:
    Sorry for the OT post Troy. I'm with RT1 on this one, there are fine pre's with a remote. Get yourself one.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • steveinaz
    Yep, to the Benchmark (2-channel PCM). My "HT" (if you want to call it that) is 2-channel.
    See my connection scheme (requires excel): http://members.cox.net/stepheninaz/audio_connection_scheme.xls
  • WilliamM2
    WilliamM2 Posts: 4,806
    vc69 wrote: »
    Steve,
    With a Benchmark pre, it's either that or optical.
  • steveinaz
    There is one 2-channel analog input, but its unused right now....
  • vc69
    vc69 Posts: 2,500
    WilliamM2 wrote: »
    So he's obviously not concerned with decoding the Hi-Res codecs on BD. I'm still a bit confused unless this is a two-channel or music only rig, in which case, why a BD player? No HT surround?
    Ahh, just caught your post. LoL
    Carry on....
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • steveinaz
    I'll go surround when I grow 3.1 more ears....LOL
    PCM is lossless, what's the issue? My BluRay sounds phenominal. The Benchmark accepts 24/192 from coax.
  • vc69
    vc69 Posts: 2,500
    steveinaz wrote: »
    I'm sure it does. I wasn't snapping very quickly this morning :o
    Sorry for the derail Troy.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • steveinaz
    No problem. Sorry Troy for the derail...
  • TroyD
    TroyD Posts: 13,124
    No sweat...I'm just rambling here...
    Ted, you crack me up, brother. No sweat, nothing is in the FM yet! LOL!
    BDT
  • Flash21
    Flash21 Posts: 316
    I am firmly on the integrated bandwagon. If nothing else, you have one less set of interconnects, and you can spend that money on one of your other toys.
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • Face
    Face Posts: 14,340
  • SolidSqual
    SolidSqual Posts: 5,218
    On another note, I know what you mean about the feeling to simplify. That being said, I sold all my stuff to fund other projects and to finally take what I've learned on this forum to build a truly high end system from the ground up as opposed to frankensteining. Working closely with dealers who know what they are talking about and demoing is still the only real way to get the high end experience efficiently.
  • SolidSqual
    How about a Pass Labs INT-50? That's got guts and guile.
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    Just FYI :http://www.wsdistributing.com/pages/SV-236MK.html
    That's not a bad piece and good reviews as well.
    heiney9 Posts: 25,426
  • pearsall001
    pearsall001 Posts: 5,249
    Here's something new from NAD...a possible glimpse into the future.
    http://nadelectronics.com/products/hifi-amplifiers/M2-Direct-Digital-Amplifier/
  • reeltrouble1
    http://www.wyred4sound.com/webapps/site/74030/117839/shopping/shopping-view.html?pid=362236&b_id=&find_groupid=18158
    Gawd.....I suppose having the young ones being unruly is a part of life....
    Whatever he gets will glow.
    looks like its time for a reminder. Tubes Rule
    RT1
  • Zitro
    Zitro Posts: 864
    This NAD makes me drool at the mouth a bit. I think I might treat myself to a bit of a graduation/acceptance to grad school present in the near future...
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • reeltrouble1
    steveinaz wrote: »
    that line of yours is one of my all time favorite you should copy protect that one steve.
    RT1
  • reeltrouble1
    I keep reading good things about Vincent..........I suppose BAT, Manley, Joule, Jolida, Cary would also join the most usual suspects but there are a bunch of new ones our there to consider........unitl MF gets there service stuff done (Michaleson claims they have) not sure about MF though.
    I suppose in your case Troy with the Quad's raw power is second to refinement. My worry would be the nuance of the micro detail, the congealing of the imaging, and soundstage width, the Manley Stingray was the best of the lot I owned and a nice piece and you can hook your i-pod thingy to the newer ones........:eek:
    Man what you have is dead quiet and it delivers.......I dunno bro maybe a change but lateral at best.
    RT1
    F1nut Posts: 51,710
    You've been here. 'Nuff said.
  • steveinaz
    I have been eye-balling the Vincent hybrid power amps myself.
  • madmax
    madmax Posts: 12,434
    I too am getting sick of all the crap sitting around. On one hand I want to display it but on the other hand it is always in disarray. I got to wondering, well why is it always in disarray? Because I keep plugging different things in differently. Its kinda like a toy box and if it were always orderly you would know the kid hadn't been playing. I see no real answer and I'm not going to stop playing. :)
    madmax
    Vinyl, the final frontier...
  • concealer404
    concealer404 Posts: 7,440
    I like big, full racks.
