Rewired my TT today
ben62670
ben62670 Posts: 15,969
edited December 2009 in DIY, Mods & Tweaks
Well I have the Project Debut III TT and it had the RCA's hardwired. Not fun. So I tore it a part. I installed some nice RCA Jacks and wired the ground wire to the TT. The sound is much better. I now have much better sound. I am using the cables I build here for now, but between tracks I am getting a hum. I had two others complain about it. It's not bad, but still annoying between tracks. I am experimenting with using a cap on the ground for noise suppression. I wish I had the coin for MIT's in this app.
Ben
Post edited by ben62670 on
  • hearingimpared
    hearingimpared Posts: 21,136
    If you ever get the cash, you should try Cardas tonearm wires. They are the bomb.
  • ben62670
    I'll look into that later. The next TT project is going to be making separate maple plinths for the motor and the rest. Maybe I'll do that pendulum style tt I love the looks of.
    Ben
  • mmadden28
    mmadden28 Posts: 4,283
    I have replacing the cable on my Yamaha PX-3 on my list of things to do. Its also hardwired. I bought the cable you made for Solid for his turntable from him. I'll let you know if I hear a hum or not when I get that far. I'll keep an eye on this thread in case you come up with a solution before then.
    ____________________
    Pool: Atrium 60's/45's
  • ben62670
    I know a few guys had great luck with my cables. I think it may be phono pre dependent? I have some new material for testing some new cables. I let you know how it works. BTW AQ cables have less hum.
    Ben
  • Fongolio
    Fongolio Posts: 3,516
    Have you tried it without the groundwire on at all Ben? On my Pro-ject 6.9 When I use my Denon DL-160 cart I need the groundwire on. With the Clearaudio Aurum Classic I have hum in any configuration until I romove the groundwire from the table. Go figure.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • ben62670
    I have tried it both ways. Best result was with the ground going to the actual pre, and not the phono pre.
    Ben
  • Polkersince85
    Polkersince85 Posts: 2,883
    Just for @hits and giggles, cover the wires with tinfoil . May be a shielding issue.
  • ben62670
    I used it all to make a hat:(
    Ben
  • madmax
    madmax Posts: 12,434
    ben62670 wrote: »
    Much better results around the ankles. ;)
    Vinyl, the final frontier...
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    ben62670 wrote: »
    lol
    Have any pic's of the wire job by chance? I'm wanting to completely redo mine sometime soon as well and it would be cool to see someone else's work so i could get some idea of what i'm getting into :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • zingo
    zingo Posts: 11,258
    That seems to be a theme with their entire product line...
  • ben62670
    Kim wrote: »
    Have you tried grounding the base of the arm using one of the mounting screws to the chasis ground on the phono preamp?
    Not yet! Thanks Kim
    Ben
    Ben
