plasmas
marvda1
anyone compare the samsung pn42b400p3d ($548) to the panasonic tc42px14 ($568) plasmas?
which is better?
http://www.samsung.com/us/consumer/tv-video/televisions/plasma-tv/PN42B400P3DXZA/index.idx?pagetype=prd_detail
http://www2.panasonic.com/consumer-electronics/shop/Televisions/All-VIERA-Flat-Panel-HDTVs/model.TC-42PX14_11002_7000000000000005702
which is better?
Puritan PSM156
Puritan PSM156
Post edited by marvda1 on
I read somewhere the samsungs plasmas run hot enough to fry an egg onpanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
I have the X1-series Panasonic, and am quite pleased. The only downside for me is no analog audio out... other than that a great TV at a great price!
In general, Panasonic is known more for their plasma quality than Samsung. -
I too have a panny x-series and was also surprised that the only audio out was optical - not that I use it - but I thought it was a weird/expensive connection to spec and leave out the L/R analog connection....
My 2 yr old sammy does run hot but I think samsungs have gotten cooler running.
I feel panasonic has steped up and either choice will be fine. Just look close at the extra features and get one. Either way ,you'll be happy I'm sure.Better than a comparably sized LCD too. Alot cheaper also.
Now the LED back-lit LCDs from samsung look great but $$ Is required.Most people just listen to music and watch movies. I EXPERIENCE them.
I have that Panny in our workout/Wii room, I haven't compared it with the Samsung, but I like it very much.
I did compare it with a few 1080p lcd's and I liked the pic better. I also know a couple of other's that bought it because of the same reason. IMHO the blacks are very good on that set.My equipment sig felt inadequate and deleted itself. -
think i have narrowed it down to two panasonic plasmas, the tc-42px14 ($548) and tc-42px1 ($599). question is the x1 worth the $51 difference?
1. can get the x14 18 month no interest.
2. x14 3 yr. extended $79.96 x1 5 yr. extended $200
3. native contrast ratio x14 15,000:1 x1 30,000:1
4. shades of graduation x14 4096 x1 5120
5. sub pixel control x14 yes x1 no
just about everything else equal, both are 2009 models.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
My new Samsung PNB550 does not run hot at all. If you put your hand over the top of it you feel some heat but nothing like the older models.
Get the PNB550 series, they're Samsung's biggest bang for the buck plasma. Other than Samsung, go with Pioneer or Panasonic G or S1 series.~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox -
Yeah the new Sammys don't run hot and they have great picture quality. we've got a 50" upstairs and a 42" down and they run fairly cool with great PQ, that being said I don't think you could go wrong with either Samsung or Panasonic.Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
I'm also shopping for a "Panny", found the site linked below among others, and have decided to go with a 50" G10 series. Best buy has a 50" 1080P U1 series for $899 online with an in-store pick up option. Ive read some bad reviews on the 720P X1 & X14 lines, not sure about Samsungs but they might be a better bet than either of the X1 orX14 models. I suggest doing a LOT of research before pulling that trigger!;)
http://www.thebestplasmatv.com/panasonic-plasma-tv/#s14
http://www.bestbuy.com/site/Panasonic+-+VIERA+/+50%22+Class+/+1080p+/+600Hz+/+Plasma+HDTV/9298404.p?id=1218079342566&skuId=9298404 -
HHgregg has the Samsung PN50B550 model for $989. Plus, I'm sure you could work them down another $100.~Dan
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
PS3 and Xbox -
For a screen size range between 40"-50", 1080p/720p is not much of an issue with the difference fairly negligible except for the blu ray capability I think. The Panasonic VIERA TC-P42X1 42" Plasma TV, for example, has a very high LCD TV ratings of 86 but is priced for about $577 only while its Panasonic VIERA TC-P50X1 50" Plasma TV big brother has a market price of only around $712! Well, that's a lot of savings right there if I might say!
