How to measure power to speakers
vmaxer
vmaxer Posts: 5,121
edited December 2009 in Electronics
:confused:Is there a easy way to measure the power going to your speakers with a decent multimeter?? I am trying to trace the cause of one of my speakers playing louder than the other and want to ensure thay are getting the same output from the amp.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
  • quadzilla
    quadzilla Posts: 1,543
    If you're using a multimeter, I'd just run a continuous sine wave and measure the voltage at each speaker. But if the speakers have multiple drivers, it's also possible that a single driver is out. I know that happened to me after I pushed a 1000 watts into each of my RTi12s.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Bubinga99
    Bubinga99 Posts: 283
    How about just swapping the speaker wires
  • DarqueKnight
    DarqueKnight Posts: 6,765
    quadzilla wrote: »
    Bubinga99 wrote: »
    These are good suggestions. You will need to use a test tone because music varies too much in sound level and frequency and it causes too much instantaneous variation in the speaker's impedance.
    Another thing to consider is that there could be some acoustic imbalance in the room (wall proximity, furniture placement, etc.) that causes one speaker to seem louder than the other.
    There might also be an imbalance in the outputs of your preamplifier, source, or amplifier. Some small variation in output level between the channels of a stereo amp is not unusual, but when the difference is audible, some adjustment should be made. Channel imbalances in source components are rare. Balance controls in preamps sometimes develop more noise in one channel than the other.
    You might also have a combination of two or more of room acoustic effects, source channel imbalance, preamp channel imbalance, amp channel imbalance, and something wrong inside the speaker.:(
    Problems with the source or preamp can be ruled out (or in) just by switching sources or switching preamps.
    To determine if there is any imbalance in your amplifier channels. Use a sine wave test tone and measure the output voltage at both channels with either an 8 ohm resistor or the same speaker used for loading.
    If the amp output levels are close to each other, connect each speaker in turn to a single amp channel. Measure the output voltage with each speaker connected and use a sound level meter to measure the sound output at the same distance in front of each speaker. To negate any possible room effects, measure each speaker at the same location in the room.
    If the amp tests ok and the speakers test ok, swap the location of the speakers to see if the louder speaker becomes the quieter speaker while both are playing the test tone.
    If the amp is ok and one speaker is actually much louder than the other, then you will need to test the lower volume speaker's drivers. Hopefully it will be a driver issue and not something wrong with the crossover.
    Tracing the source of sound level imbalances is about as much fun as tracing the source of a ground loop. They both are only slightly less aggravating than a mild toothache.
    Have fun.
  • vmaxer
    vmaxer Posts: 5,121
    Thanks a lot DK, Bubinga99, and quadzilla....:)
    I would prefer the mild toothache any day as this isn't any fun at all to me.:o
    Hopefully, I can do this over the week-end, it has been bothering me for a while.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Could also be as simple as having the plastic coating from the speaker wire inside the speaker connection. Check both ends,speaker and amp.
  • hearingimpared
    hearingimpared Posts: 21,136
    vmaxer wrote: »
    I don't envy that job.
  • quadzilla
    Based on what DK and Tony just said, another thought has occurred to me. What are you using for speaker wire termination? Bare wire? Spades? Bananas? Could those be damaged? Or was anything heavy rolled over/put on the speaker cable which could have damaged the cable itself by breaking the conductor?
    Arm: Rega 300
  • crogers227
    crogers227 Posts: 26
    I had to do the same thing and it took me two days of messing with it a little each day to realize one of my banana clips was causing the problem. I dont envy you one bit. Good luck.
    A/V Receiver...........Denon 1910
    Power Conditioner....MP HD IR 2550
    BluRay Player..........Sony PS3
    Fronts....................RTi 100
    Center...................CSi3
    Surrounds...............FXi3
    Sub.......................Micropro 3000 :D
    Extras....................Harmony One, Xbox 360, Wii
  • vmaxer
    vmaxer Posts: 5,121
    quadzilla wrote: »
    I bought a set of PNF Audio cables a 2 - 3 months ago with bananas and haven't damaged them. I had the problem before the change also??:confused:
    Thanks for the tips, I will also check them.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
