How to measure power to speakers
vmaxer
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
If you're using a multimeter, I'd just run a continuous sine wave and measure the voltage at each speaker. But if the speakers have multiple drivers, it's also possible that a single driver is out. I know that happened to me after I pushed a 1000 watts into each of my RTi12s.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
How about just swapping the speaker wires
If you're using a multimeter, I'd just run a continuous sine wave and measure the voltage at each speaker. But if the speakers have multiple drivers, it's also possible that a single driver is out. I know that happened to me after I pushed a 1000 watts into each of my RTi12s.How about just swapping the speaker wires
These are good suggestions. You will need to use a test tone because music varies too much in sound level and frequency and it causes too much instantaneous variation in the speaker's impedance.
Another thing to consider is that there could be some acoustic imbalance in the room (wall proximity, furniture placement, etc.) that causes one speaker to seem louder than the other.
There might also be an imbalance in the outputs of your preamplifier, source, or amplifier. Some small variation in output level between the channels of a stereo amp is not unusual, but when the difference is audible, some adjustment should be made. Channel imbalances in source components are rare. Balance controls in preamps sometimes develop more noise in one channel than the other.
You might also have a combination of two or more of room acoustic effects, source channel imbalance, preamp channel imbalance, amp channel imbalance, and something wrong inside the speaker.:(
Problems with the source or preamp can be ruled out (or in) just by switching sources or switching preamps.
To determine if there is any imbalance in your amplifier channels. Use a sine wave test tone and measure the output voltage at both channels with either an 8 ohm resistor or the same speaker used for loading.
If the amp output levels are close to each other, connect each speaker in turn to a single amp channel. Measure the output voltage with each speaker connected and use a sound level meter to measure the sound output at the same distance in front of each speaker. To negate any possible room effects, measure each speaker at the same location in the room.
If the amp tests ok and the speakers test ok, swap the location of the speakers to see if the louder speaker becomes the quieter speaker while both are playing the test tone.
If the amp is ok and one speaker is actually much louder than the other, then you will need to test the lower volume speaker's drivers. Hopefully it will be a driver issue and not something wrong with the crossover.
Tracing the source of sound level imbalances is about as much fun as tracing the source of a ground loop. They both are only slightly less aggravating than a mild toothache.
Have fun.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Thanks a lot DK, Bubinga99, and quadzilla....:)
I would prefer the mild toothache any day as this isn't any fun at all to me.:o
Hopefully, I can do this over the week-end, it has been bothering me for a while.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Could also be as simple as having the plastic coating from the speaker wire inside the speaker connection. Check both ends,speaker and amp.HT SYSTEM-
lsi 9's -
I don't envy that job. -
Based on what DK and Tony just said, another thought has occurred to me. What are you using for speaker wire termination? Bare wire? Spades? Bananas? Could those be damaged? Or was anything heavy rolled over/put on the speaker cable which could have damaged the cable itself by breaking the conductor?Turntable: Empire 208
Arm: Rega 300
I had to do the same thing and it took me two days of messing with it a little each day to realize one of my banana clips was causing the problem. I dont envy you one bit. Good luck.A/V Receiver...........Denon 1910
Power Conditioner....MP HD IR 2550
BluRay Player..........Sony PS3
Fronts....................RTi 100
Center...................CSi3
Surrounds...............FXi3
Sub.......................Micropro 3000
Extras....................Harmony One, Xbox 360, Wii -
I bought a set of PNF Audio cables a 2 - 3 months ago with bananas and haven't damaged them. I had the problem before the change also??
Thanks for the tips, I will also check them.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
