PSW 505 Wiring Setup
webbcw
webbcw Posts: 5
Just recd a new 505 Subwoofer. Reading the manual to hookup; it seems the instruction are opposite to the figure 6.
Words say "connect the left and right front speaker outputs of your receiver or amplifier to the speaker level inputs of the powered subwoofer using speaker wire."
But figure 6 shows the receiver wires going to speaker level output terminas instead and the right receiver terminal going to the left speaker level output terminal of the subwoofer.
I appreciate any help in order to understand.
Thanks very much
Post edited by webbcw on
  • dorokusai
    dorokusai Posts: 25,576
    edited December 2009
    Do you have a subwoofer or LFE output on your Receiver/AVR?
  • webbcw
    webbcw Posts: 5
    dorokusai, no. I have an older ONKYO ASV610Pro
  • webbcw
    webbcw Posts: 5
    Also I have 2 RTi A3 main speakers
  • dorokusai
    Run speaker wire from the Left and Right(Front) speaker outputs on the Onkyo, to the L&R speaker inputs on the PSW505. Then run speaker wire from the L&R subwoofer outputs to the actual loudspeakers.
    Better?
    EDIT: I just looked at the manual and it's incorrect. You already had the right idea, just reverse the words on the diagram.
  • webbcw
    webbcw Posts: 5
    dorokusai, Thank you VERY much for the help. I feel I can wire now with the assurance that I will not do any damage or implement in a sub-par way.
    This forum is really great with people like you here.
    Very grateful. :)
    Thanks much again.
  • dorokusai
    :D Cool man, post some pics in the system showcase when you get all setup.
