Best way to clean speaker grills?
halo71
What is the best way to clean, what I can only guess is mold from speakers grills? Its a white powdery looking stuff, from maybe sitting in a basement. I am thinking using dilluted vinegar maybe?
--Gary--
Post edited by halo71 on
Take them outside and brush off as much mold as possible. Then use mild bleach and/or lemon juice and salt solution. Dry them in the sun to kill the remaining spores.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I did not have any mold on my 'new' speaker grills, but I had very good luck using my steam cleaner.They look like new.
FYI: If your grill frames are made from MDF, install them back on the speakers while they are fully dried, as the MDF can warp from added moisture.
Course I just did mine, so I can't give you any long term effects, so try it at your own risk.
My SurroundBar and PSW10 have synthetic fiber cloth on plastic frames. They had some spots on them and I was able to wash them in the bathtub immersed in some warm water and dish soap. Left them in the sun to dry. No problems washing them this way but I wouldn't wash grills with particle board frames this way.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
A steam cleaner would do a good job it seems as stated above. I'm not sure I'd try anything with bleach or you might end up with discoloration or some kind. What about a light ammonia mix with a wet/dry vac to suction them off?
mold tends to discolor fabric...permanently..consider recovering them.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Halo, do you have plastic or MDF grill frames? IF they are plastc, I was just thinki one coul actually try re-dyeing with fabric dye, after cleaning, if they were discolored. You could always recover them if it didn't work. IF they are MDF I would go easy on the liquids.
Good luck
Thanks for the info. But the "deal" I had on acquiring these speakers fell through. So.....no need to clean them now.
--Gary--
