Best way to clean speaker grills?
halo71
halo71 Posts: 4,630
edited December 2009 in DIY, Mods & Tweaks
What is the best way to clean, what I can only guess is mold from speakers grills? Its a white powdery looking stuff, from maybe sitting in a basement. I am thinking using dilluted vinegar maybe?
--Gary--
Post edited by halo71 on
  • quadzilla
    quadzilla Posts: 1,543
    Take them outside and brush off as much mold as possible. Then use mild bleach and/or lemon juice and salt solution. Dry them in the sun to kill the remaining spores.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • kcoc321
    kcoc321 Posts: 1,788
    I did not have any mold on my 'new' speaker grills, but I had very good luck using my steam cleaner.They look like new.
    FYI: If your grill frames are made from MDF, install them back on the speakers while they are fully dried, as the MDF can warp from added moisture.
    Course I just did mine, so I can't give you any long term effects, so try it at your own risk. :)
  • jimbo1421
    jimbo1421 Posts: 772
    My SurroundBar and PSW10 have synthetic fiber cloth on plastic frames. They had some spots on them and I was able to wash them in the bathtub immersed in some warm water and dish soap. Left them in the sun to dry. No problems washing them this way but I wouldn't wash grills with particle board frames this way.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • zingo
    zingo Posts: 11,258
    A steam cleaner would do a good job it seems as stated above. I'm not sure I'd try anything with bleach or you might end up with discoloration or some kind. What about a light ammonia mix with a wet/dry vac to suction them off?
  • Knucklehead
    Knucklehead Posts: 3,602
    mold tends to discolor fabric...permanently..consider recovering them.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • kcoc321
    Halo, do you have plastic or MDF grill frames? IF they are plastc, I was just thinki one coul actually try re-dyeing with fabric dye, after cleaning, if they were discolored. You could always recover them if it didn't work. IF they are MDF I would go easy on the liquids.
    Good luck :)
  • halo71
    halo71 Posts: 4,630
    Thanks for the info. But the "deal" I had on acquiring these speakers fell through. So.....no need to clean them now. :D
    --Gary--
