electronics wizards "pcb" help
  • skrol
    skrol Posts: 3,452
    edited December 2009
    To me, it looks like physical damage and not electrical overstress. It also looks like a single layer PCB. If you have difficulties re-soldering the lead back into the existing hole, you could drill another hole through the foil and board, scrape some of the varnish and solder the lead through the new hole.
    BTW, I hope the speaker is not laying face down on the tweeter.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • sandworms
    sandworms Posts: 1,043
    skrol wrote: »
    uh oh! i did have it face down on a padded bench, i dont feel any damage to the tweeter but that doesn't mean anything does it? it appears ok by visual insp. my bad
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
    tonyb Posts: 33,072
    If your unsure of your ability to tackle the repairs,I would get 2 new crossovers and bring both speakers to someone who knew what they were doing. This however doesn't mean the rest of the speaker is OK. Man, you really took a shot in the dark with these puppies dude.
  • sandworms
    you only live once!! anyway, i looked at the backside of the board and see no damage, no burns or anything out of wack. i just thought that i could finally get a shot at owning some lsi's on the cheap, time will tell if i got totally screwed or not. yeh, they're not cosmetically sound but a little tlc and they could make some decent basement or garage speaks
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • TECHNOKID
    TECHNOKID Posts: 4,298
    1. If you look at the coil it self, it seems to be slightly damaged therefore measure it to make sure it is still good (neither shorted or open).
    2. I see at least 4 solder in the center that seemed to have been tampered with, check if the tracks weren't damaged...
    3. The pad is lifted off the board; a portion of the pad remained attached to the coil lead, you can see the naked board in the area where it was located, the remainder of the pad is also damaged at the board.
    4. If and only if the coil is still good, the only way to fix such is to remove the broken pad of the coil, gently scrape the coating of the remaining run and resolder the coil at that location. I hope you have a good heat controlled soldering gun and that your skills are good as well.
    5. According to your last post you say the remainder of the board is good? That is important otherwise you are wasting your time.
    6. If you are not the best skilled at soldering, like tonyb says order replacement Xo.
    Cheers and good luck!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • sandworms
    this is the main concern for which i started the thread, trying to find out if the tearing of the pad would be fixable. considering i don't have the correct tool for the fix, i would need to borrow one, which may not be possible. i may just look to see how much a new xo will be, but in the end i will not give up till i hear these. i'm fairly confident they won't run me too much $ to get them back in shape, and i will keep updating those who spent the time to help save these poor speakers
    thankyou everyone, again your time and advice is greatly appreciated
    Samsung pn64f8500
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • Face
    Face Posts: 14,340
    It appears the lifted pad is at the beginning of the LF filter. You can just run the LF + wire from the binding posts directly to the side of the coil that lifted off the board.
