Refrigerator is noisy
naz11
naz11 Posts: 5
edited December 2009 in DIY, Mods & Tweaks
My Sanyo Sr-290 compact fridge is really noisy. When i plug it in it starts to make a very loud buzzing noise. I have no clue what the problem is.:confused:
Post edited by naz11 on
  • kcoc321
    kcoc321 Posts: 1,788
    IS the noise inside the freezer or from the back.
    Something is hitting the fan.
    IF it is from the freezer section, try defrosting the freezer by removing everything and leaving it unplugged for a day with the door open.
    I have had to do that on a small refer I have, sometimes every 6 months.
    Ice builds up inside and the internal fan blades hit it.
    But it is really humid here in Seattle.
    IF it from the back, something is hitting the small fan, usually in the bottom.
    Did you move it around recently? Maybe something got pushed in there.
  • NJPOLKER
    NJPOLKER Posts: 3,474
    Do you own a shotgun? If so use it. It will be quiet after the muzzle bast fades away and the ringing in your ears subsides
  • naz11
    naz11 Posts: 5
    the noise is from the bottom and i dont own a shotgun sorry and it is interesting:D
  • naz11
    naz11 Posts: 5
    i did move it around recently,BUT i moved it to check on the noise...
  • Face
    Face Posts: 14,340
    Kex wrote: »
    So ... now ... why did you post this in Club Polk?
    Why not, people ask for medical advice here?
  • naz11
    naz11 Posts: 5
    the second pic is sideways, but the noise is coming from the black thing. when i move it a little in any direction the noise goes from a loud buzz to a soft hum.
  • MrGlobe
    MrGlobe Posts: 401
    Well what kind of AVR are you using man? Honestly I'm not sure its ever a good idea to plug a fridge into your stereo. I was also unaware that Polk made a fridge.
  • naz11
    naz11 Posts: 5
    its been off for the past week with no movement and i just tryed it and it still makes the noise
  • ken brydson
    ken brydson Posts: 9,005
    naz11 wrote: »
    Have you tried toeing it in a bit. Maybe better cables?
  • messiah
    messiah Posts: 1,790
    naz11 wrote: »
    The noise will stop if you unplug it :rolleyes:
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • BlueFox
    BlueFox Posts: 15,251
    Mine is noisy also, so I put it in the garage. After building up my 2 channel system in the living room, I was not going to tolerate a noisy refridgerator in the kitchen. It turned out to be a big improvement as it freed up room in the kitchen, in addition to making the front part of the house nice and quiet.
  • messiah
    BlueFox wrote: »
    Yep, it makes room for kitchen speakers :D
  • mesquitehead
    mesquitehead Posts: 312
    Keiko wrote: »
    On a more serious note. That black thing is the compressor. And it's probably failing from the sound of it. Time for a new fridge, naz.
    Compressor could be failing..or it could just be a vibration from the compressor rubbing against something down there. A little fridge will have a thermal overload on it and it will shut down a compressor that is getting hot due to bad windings..the buzz could be a bad compressor if it is short intervals...it gets hot at start up then the thermal shuts it down till it cools off. Or it could be a fan blade hitting something (casing or ice maybe) or the hubon the blade may have come loose and the fan blade is not tight on the fan motoer shaft. It could be many things but I would look for those first. And fyi it is cheaper to buy a new mini than it is to call a repairman and limp an old one along.
    "Thats great... but how does it sound"
    http://www.burginmcdaniel.com/
    http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
    Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
    2007 Tundra 5.7 TRD DC
    Pioneer DEH-80PRS
    Polk SR6500
    SI BM 12" subs
    Zed Gladius
    Zed Deuce
  • madmax
    madmax Posts: 12,434
    Kex wrote: »
    Ok, so it's extremely difficult to take this thread seriously ...
    A noisey fridge is nothing to laugh at when it comes to audio. Its a damn serious situation naz11 has gotten himself into.
    madmax
    Vinyl, the final frontier...
  • messiah
    Maybe if you dynamat the compressor?
  • inspiredsports
    inspiredsports Posts: 5,502
    removed
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Polkitup2
    Polkitup2 Posts: 1,642
    madmax wrote: »
    madmax
    I actually had to put an automatic timer on my bar fridge to restrict its run time because it would drive me nuts when I was listening to tunes.
