Audiobahn????
smansonsmanson Posts: 3
edited December 2009 in Car Subwoofer Talk
are audiobahn subwoofers any goood????
and what about hifonics amp?????
Post edited by smanson on
  • smansonsmanson Posts: 3
    edited November 2009
    i just wanted to know if they knock hard and if the amp is good
  • FongolioFongolio Posts: 3,517
    I've got a pair of Audiobahn's in my truck. 12" chrome flame baskets. They look cool and give me a decent back massage. Not as good SQ as the Alpine Type R's in the IROC but for the money I like them.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • ConradiclesConradicles Posts: 5,974
    I have a 12" in my Benz and it has been a great performer over the years.
  • MacLeodMacLeod Posts: 14,365
    Theyre loud. Sound like crap, built like crap and look like crap. But theyre loud......and have chrome flames.
  • zarrdosszarrdoss Posts: 2,539
    They used to be decent when they first came out and had something to prove but have to agree they're cheap crap now.
    MacLeod wrote: »
    mmmmm Chrome flames
    I like the chrome flames, they were cheap and sound at least half decent.....will they compare to the stuff you run to win competitions..no. Do they offer (or did they 5 years ago when I bought them) decent bang for the buck..yes.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
    Id argue they dont even off that. Build quality with their stuff was pretty sub par and their amps usually didnt make their rated power. So you got shoddy build quality, lousy sound quality and at best average power. They werent that cheap either.
  • atanneratanner Posts: 5
    well they are good but you dont wanna power to much to them. i had 3 10 inch audiobahns and they sounded good i only had a 600 watt jl audio amp hooked up to them. but now i am getting 2 12 inch alpine type r and a 4000 watt class d hifonics amp. and that will power them good . i would say a 600 watt to 1000 watt amp.
    -Austin
  • JstasJstas Posts: 13,906
    Not a fan of Audiobahn. Like Mac said. Cheap.
    Hifonics amps on the other hand, I like them. I've used them in several installs with much success. Others don't like them. But honestly, I've been using Hifonics stuff since the early 90's and was quite disappointed when they disappeared for a while.
    I've heard complaints that they don't make rated power but all the models I own, I haven't seen that problem. One issue is that they are not fused and have unfettered power supplies. So they are quite sensitive to voltage drops in power supplies. That leads me to suspect that the culprit of the low power is due to the voltage drop. They will suck down every ounce of power you give them and they will rock all day long. they are clean and even if they are down from the rated power, they are still stout pieces of equipment. At least in my experience that is.
    If I need new stereo stuff for a vehicle, I will certainly buy Hifonics amps again. Can't say so much for the speakers but I like the amps.
  • MrGlobeMrGlobe Posts: 401
    I had a friend that used 2 12" Audiobahns and they really pounded. Granted I am not used to listening to competition gear, stricly BB purchased systems and whatnot. But they really pounded compared the the Pinoneers, Duals, Type Rs and the like that i've heard.
  • StuFunkStuFunk Posts: 3
    I've used HIFonics since the early 90's myself and got them real freakin hot a few times but, I've never had one quit and SQ per dollar ratio is pretty darn good.
  • john Ejohn E Posts: 32
    I would'nt waste money on audiobahn subwoofers or hifonics amps ,the subs are pretty cheaply made and hifonics amps are not that good .A 4000 watt will draw around 300amps and you better have a 200amp alternator and some good deep cycle Battery like a yellow Top Optima.Rockfordfosgate makes great amps and subwoofers ,there power amps are always underrated,I bought a Power T3002 that is just rated a 100watts x 2 and 300watts bridged ,but the actual power that it put out was 978 watts bridged at 2 ohms at 14.4volts.You can usally find a good secound hand or refrubished at a reasonable price.I have a Rockfordfosgate Type RF-X7 amp that was there top amps when they first came out.They cost over a $1000 when new .It was rated at 1300watts at 12.6volts and it was 85% efficent.It birthsheet showed that it really put out 1856watts at 14.4volts at 2 ohms bridged .I been wanting to sell it for $300 The Rockfordfosgate Power T1 woofers are well built and sound great if you have your box build right and the port tuned right.the Alpine type r woofers are good too.I would get a Alpine sub-amp over hifonics.the PDX are the best ones since they are digital class D amps and are around 90% effcient.The PDX-1.1000 draw only around 90amps while putting out 1100 watts.The Alpine MRP-M2000 is a 80% effcient amp that puts out over 2000watts clean.You need a lot of amps for hifonics amps and they are not the cleanest amp.iF you are going with a pair of 12" Alpine Type R ,then I would go with a more effcient and cleaner amp.I would go with the Alpine MRP-M2000 that put out 2000watts or a Rockfordfosgate T-1500-1BD which can be found as low as $420 and most of them put out 1700 to 1800 watts at 14.4voltsthe sound quality will be so much better then hifonics.I managed a stereo shop for over 8 years.hifonics will put out a lot of power ,put you need a lot of power to get it to put it out .most of the hifonics I installed did not put out what they were rated.
    ONKYO TX-SR607
    PolkAudio Speakers
    Front-Monitor 70's
    Center-CS2
    Sur-round-Monitor 40's
    Sur-round Back-Monitor 60's
    Subwoofer-PSW-505
    Back fill in Bass PSW-10
    LG 50"Black 1080P Plasma HDTV (50PS60)
    LG Blu-Ray Disc BD390
    Wow! Cant believe that was nearly 4 years ago! That was the dude that built his sub box out of CARDBOARD!!!
  • dudeinaroomdudeinaroom Posts: 3,625
    john E wrote: »
    Just go out and get a whole bunch of maxxsonics stuff and you'll be set John.:p
    MacLeod wrote: »
    crazy huh.
  • Installer4lifeInstaller4life Posts: 256
    MacLeod wrote: »
    plus 1!! saw this brand for sale in a grocery store a few years back....no kidding..
    john E wrote: »
    What the hell is this rambling pile of dog crap?
    It looks like it was cut and pasted from Alpine and Rockford Fosgate brochures and punctuation was not even an after thought let alone a concern.
    I cant tell. My ADD goes haywire just looking at that post. No way I could read all that mess.
    MacLeod wrote: »
    +1 fo sho
Howdy, Stranger!
