Do SDA 1Cs sound better with the grills off??
geppy1
Does anyone have an opinion on this?? Keith
Post edited by geppy1 on
When I owned them, I liked them off. Both my wife and I noticed a very slight difference in the higher frequency range. Plus they just look better too!
Keep in mind my pair had the stock cloth, some people go for a more 'transparent' material.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
I like to listen to my speakers naked at every possible oppurtunity. It just sounds better that way.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »I like to listen to my speakers naked at every possible oppurtunity. It just sounds better that way.
He asked about the speakers themselves with or without grills, not whether or not you have anything on. TMI imo...:rolleyes:Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Errr.... the speakers. Not me, necessarily. Not always possible for me to leave the grills off... the cats like to get into the speakers. Would rather they tear up a grill than a cone.
That's not gone well....He asked about the speakers themselves with or without grills, not whether or not you have anything on. TMI imo...
I hate you.
I normally listen to mine with the grills on, but I can definately tell the difference in sound if I take them off.
Which one sounds better is really up to you, and probably depends a lot on the characteristics of your entire system.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9 -
With the SL2000s I did not notice any difference. With the RD 194s I thought they sounded better with them off. I changed out the heavy grill cloth for lighter material and now they sound the same with grills on or off.Speakers: SDA-1C (most all the goodies)
