Woofer not working
ryan200606
Hi, my PSW250 is not working. it used to work but one day it just stopped. i thought it was the fuse but i got a new one and it still doesnt work. the green power light does not come on. what could be wrong?
Post edited by ryan200606 on
Take all fingers, evenly around the dust cap, and gently press down, not to far and see if you hear any rubbing. Report back.
It also could be the amp. Call Ken at CS.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
hey i heard a noise so what does that mean?, if its the amp what can i do about that?
If you heard a noise when you pressed down on it, like a rubbing. That means you blew the voice coil. However, if the green light dosn't come on, that means no power is going to the subwoofer. Which means you might need a new woofer and an amp. Power surge maybe?
so basically my subwoofer is done with?
Well, if it dosn't turn on. Your sub makes noise when you press it in. It makes no sound. I would say so. Call Ken and ask him about replacement parts for it. Did you buy it from an authorized dealer (crutchfield, circuit city, etc)?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
yes i did by it from circiut city but it was along time ago and i have no idea were my reciept is
Hmm, Call Ken or E-Mail him. I'm sure if you search threads he has replied to you can get his E-Mail or phone number. I don't know it, it is also in the contact section on the main page. He is the only one that can help you now! Good luck!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
ryan,
Welcome... sorry to hear of your sub's apparent demise.
You did not say whether the original fuse was blown or not... was it? I'll guess not, since you got nothing when you put the new one in. If the old one had blown, you should have at least gotten the light to flash on as the replecement blew.
As Sid is urging you, chat with Ken, but does sound like your sub is dead. If you dropped the Voice Coil, it's probably shorted out, keeping the sub's amp in a protection mode and from turning on (I'm guessing here assuming the fuse is OK).
Also call CC, they should be able to pull up your records and see if you are stilll in waranty...
Please post anything more you learn so we can learn, too.More later,
Tour...
Vox Copuli
Today I heard that same rubbing noise on one of my RTI38's
blown coil. Do these coils fail on their own or would it be something that I have done?
Spoke to the dealer I bought them from and sounds like the are going to fix it under warranty which is great. If for some reason they can't fix them they said they would give me the newer model on the market which I assume are the RTI6 anyway, I blew a coil too and it sucks.
Would Polk replace the coil for free minus the shipping? Just curious -
Yes, if under warranty. Call Ken- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sounds like your dealer is going to take care of you, you should be fine, the replacement woofer is available to them.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Why call Ken? He has a dealer to fix it.Dodd - Battery Preamp
You don't like to talk to Ken?
More later,
Tour...
Vox Copuli
I just think if you have a speaker under warranty, and a dealer, why call Polk CS direct? We all know Ken has done wonderful things, but to ALWAYS suggest everyone "call Ken" is not the proper thing to do. I mean what if every single person who bought Polk speakers called Ken, poor guy would never be able to go home. Just my thoughts.Dodd - Battery Preamp
So... you do like to tlak to Ken? :cool:More later,
Tour...
Vox Copuli
Im taking them in today. The dealer said that I could be without them for upto 60 days while they get fixed. It will be a long 60 days without them
Maybe he's got some loaners...More later,
Tour...
Vox Copuli
then Email Ken.....:D
I've been Emailing him about a problem I'm having......
very fast responses.....great support so far.....
