Dumb Question...but what is "bi-wiring"?
pbc74
can someone please explain what this means? Thanks.
Main system:
Fronts: Infinity Alpha 50
Center: Infinity Alpha 37c
Surrounds: Infinity Alpha 20
Receiver: Onkyo TS-XR607
Subwoofer: Pioneer S-DW1-K
Cable- Monster Cable XP
Bedroom Setup:
fronts- Polk R50
surrounds- Polk R30
center- CS1
sub- Sony 50 watt
AVR- Onkyo TSXR502
Bedroom Setup:
fronts- Polk R50
surrounds- Polk R30
center- CS1
sub- Sony 50 watt
AVR- Onkyo TSXR502
Post edited by pbc74 on
Hey pbc, welcome to the forum. There are many experts on this forum, I am not one, but I'll try and help you out. Bi-wiring is running two speaker cables from the amp to the two separate binding posts on the speaker. You need two separate posts to bi-wire and you must remove the gold plates that connect the +s and -s. I believe the theory is that the low current high frequecy signals are separated from higher current low frequency signals thus reducing electromagnetic interference that you could have with one cable. If I dont remember correctly then someone will come along to set me straight.Graham
No question is a dumb question
Welcome and here is a pic to further explain your question. What setup you got? Life without music would♭ -
ok it wouldnt let me post it so see this thread for it...:p http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=12511Life without music would♭
Check out this site. you'll find an extensive explanation of bi-wiring
http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/audio/biwire/Page1.html
Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
Sub - JTR Captivator S2 (Dual 18")
Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35 -
Thanks for the link, malikarshad. A lot more on the site for reading later...
As for the bi-wire exercise... a lot of effort, even with the generous assumptions, to conclude "maybe/ maybe not... depends on the listener". That is pretty much what an empirical sampling of the members would produce...
Welcome pbc..More later,
Tour...
Vox Copuli
thanks for all the responses! that answered my question.
spasticpitbull- I'm just getting started with Polk. I have R30 fronts, R15 surrounds, and a CSI20 center. It's an upgrade for me because I had a cheapie pioneer setup from circuit city. I just recently upgraded all my speakers with their upgrade program. Right now I have a Kenwood VR605 receiver that I will eventually get an Onkyo to replace it.Main system:
Bedroom Setup:
fronts- Polk R50
surrounds- Polk R30
center- CS1
sub- Sony 50 watt
AVR- Onkyo TSXR502
Cable- Monster Cable XP -
I am right there with you. I have well taken advantage of the CC upgrade program. And am still upgrading. The wife hates it but....Oh well! Good luck!:DLife without music would♭
