Power for LSi9's
If I plug my LSi9's into my Emo XPA-3 will it screw up my speakers? The LSi9's are rated for up to 200W and the XPA-3 puts out 300W into 4 ohms. So...is the XPA-3 too much power for the LSi9's? I have read some guys say you can't over power a speaker, but you can certainly under power one. I understand clipping well enough. I am now just worried about over powering by 50%!
Post edited by ls7z06 on
As long as you don't listen at concert levels, you should be fine."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
You won't have a problem imo.
Just because you've got them hooked up to the amp, it doesn't mean your speakers are seeing 300 watts at all times/at all volumes.
I haven't heard LSi's, but I would assume your ears would run out on you before those speakers get loud enough to even see 250watts as you're turning it up. Like I mentioned though, it's about how loud you're playing it that'll determine how much power they'll see.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
You aren’t feeding the speakers 300 watts, the rating on your amp means you have 300 watts available should it be required. The more watts your amp can pump out the more headroom you will have, which is a good thing. I'm sure that amp will be just fine and dandy for a pair of 9's, turn'em up and enjoy!Mains - Vienna Acoustics Mozart Grand
Subs - Rel T5 x 2
Amplification - Bryston 3b cubed
Pre Amp - Marantz Sc11-1
SACD - Marantz Sa11-1
Stream - Cambridge Audio CXN v2
Dac - Marantz Dac-1
TT - Pro-Ject RPM 9.1 w/ Ortofon 2M Black Cartidge
Phono Stage - Project Tube box DS -
You should be fine... but keep a fire extingusher handy just in case.:p
J/k emofans... relax.;)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
You will not have a problem. Better too much than too little.Michael
NORTH of 60° -
I'm running a pair of LSi9s with an XPA-5 rated at IIRC 450 wpc into 2 channels at 4 ohms. It's nice.
Same here.Things work out best for those who make the best of the way things work out.-John Wooden -
I use LSi Series. Sunfire amplifier with 800 watts per channel and I've never had a problem. LSi with Sunfire is
hear the angels sing.
01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
02) SUNFIRE Grand Signature - Bob Carver's
03) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
04) OPPO BDP-83 Blu-ray Disc Player w/SACD & DVD-Audio / DENON DVD-2500BTCI: Blu-ray Disc DVD/CD Digital Player/Transport
05) HITACHI P55T501. 55" HD1080 Plasma HDTV
06) POLKAUDIO LSiC (Center speaker)
07) POLKAUDIO LSi15 LEFT (Front speaker)
08) POLKAUDIO LSi15 RIGHT (Front speaker)
09) POLKAUDIO LSif/x LEFT (Surround speaker)
10) POLKAUDIO LSif/x RIGHT (Surround speaker)
11) VELODYNE OPTIMUN SERIES (High Output Digital EQ SubWoofer 2400W/1200WRMS) -
I've heard rumors that the LSi9's can dip to 2ohms..........you should have no problems... enjoy! BTW mine are getting 385 per channel for the mid-bass and 200 per channel for the tweets....from two Parasound amps..:D"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
I have the LSi 9's and have been struggling with sound when I play music. I've been doing a lot of reading to try and figure this out and it was suggested that because the 9's are rated at 4ohms, they are not an ideal match for most amps, receiver, etc. I'm wondering if this is the case with mine. I have an Onkyo TX-SR701 and am wondering if it's not compatible.
Based on the Onkyo website, here are the specs:
Power Specifications
Power Output* (8 ohm, 20 Hz-20 kHz, FTC) -
Front L/R 100 W/Ch
6 ohm Capable -
4 ohm Capable -
Center 100 W
Surround L/R 100 W/Ch
Surround Back 100 W
Dynamic Power** -
3 ohm (Front) 230 W/Ch
4 ohm (Front) 170 W/Ch
8 ohm (Front) 115 W/Ch
Any input would be greatly appreciated. I want so much to love these speakers and serve them justice! -
You need an external amp. If your budget is really tight, check out Adcom."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
nooshinjohn wrote: »You should be fine... but keep a fire extingusher handy just in case.:p
Thats a good one!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Why, he's not using Carver or Flame Linear.nooshinjohn wrote: »You should be fine... but keep a fire extingusher handy just in case.:p"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
