Power for LSi9's
ls7z06
ls7z06 Posts: 95
edited December 2009 in Speakers
If I plug my LSi9's into my Emo XPA-3 will it screw up my speakers? The LSi9's are rated for up to 200W and the XPA-3 puts out 300W into 4 ohms. So...is the XPA-3 too much power for the LSi9's? I have read some guys say you can't over power a speaker, but you can certainly under power one. I understand clipping well enough. I am now just worried about over powering by 50%!
Post edited by ls7z06 on
  • Face
    Face Posts: 14,340
    edited November 2009
    As long as you don't listen at concert levels, you should be fine.
  • kawizx9r
    kawizx9r Posts: 5,150
    You won't have a problem imo.
    Just because you've got them hooked up to the amp, it doesn't mean your speakers are seeing 300 watts at all times/at all volumes.
    I haven't heard LSi's, but I would assume your ears would run out on you before those speakers get loud enough to even see 250watts as you're turning it up. Like I mentioned though, it's about how loud you're playing it that'll determine how much power they'll see.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Bass_Pedal
    Bass_Pedal Posts: 196
    You aren’t feeding the speakers 300 watts, the rating on your amp means you have 300 watts available should it be required. The more watts your amp can pump out the more headroom you will have, which is a good thing. I'm sure that amp will be just fine and dandy for a pair of 9's, turn'em up and enjoy!
    Mains - Vienna Acoustics Mozart Grand
    Subs - Rel T5 x 2
    Amplification - Bryston 3b cubed
    Pre Amp - Marantz Sc11-1
    SACD - Marantz Sa11-1
    Stream - Cambridge Audio CXN v2
    Dac - Marantz Dac-1
    TT - Pro-Ject RPM 9.1 w/ Ortofon 2M Black Cartidge
    Phono Stage - Project Tube box DS
    nooshinjohn Posts: 25,883
    You should be fine... but keep a fire extingusher handy just in case.:p
    J/k emofans... relax.;)
  • janmike
    janmike Posts: 6,146
    You will not have a problem. Better too much than too little.
    Michael ;)
    NORTH of 60°
  • Hilbert
    Hilbert Posts: 316
    I'm running a pair of LSi9s with an XPA-5 rated at IIRC 450 wpc into 2 channels at 4 ohms. It's nice. :)
  • PSOVLSK
    PSOVLSK Posts: 5,371
    Hilbert wrote: »
    Same here.
  • Bernal
    Bernal Posts: 991
    I use LSi Series. Sunfire amplifier with 800 watts per channel and I've never had a problem. LSi with Sunfire is
    hear the angels sing.
    01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    02) SUNFIRE Grand Signature - Bob Carver's
    03) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
    04) OPPO BDP-83 Blu-ray Disc Player w/SACD & DVD-Audio / DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
    05) HITACHI P55T501. 55" HD1080 Plasma HDTV
    06) POLKAUDIO LSiC (Center speaker)
    07) POLKAUDIO LSi15 LEFT (Front speaker)
    08) POLKAUDIO LSi15 RIGHT (Front speaker)
    09) POLKAUDIO LSif/x LEFT (Surround speaker)
    10) POLKAUDIO LSif/x RIGHT (Surround speaker)
    11) VELODYNE OPTIMUN SERIES (High Output Digital EQ SubWoofer 2400W/1200WRMS)
  • xj4094dg
    xj4094dg Posts: 1,158
    I've heard rumors that the LSi9's can dip to 2ohms..........you should have no problems... enjoy! BTW mine are getting 385 per channel for the mid-bass and 200 per channel for the tweets....from two Parasound amps..:D
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • NewKidInTown
    NewKidInTown Posts: 2
    I have the LSi 9's and have been struggling with sound when I play music. I've been doing a lot of reading to try and figure this out and it was suggested that because the 9's are rated at 4ohms, they are not an ideal match for most amps, receiver, etc. I'm wondering if this is the case with mine. I have an Onkyo TX-SR701 and am wondering if it's not compatible.
    Based on the Onkyo website, here are the specs:
    Power Specifications
    Power Output* (8 ohm, 20 Hz-20 kHz, FTC) -
    Front L/R 100 W/Ch
    6 ohm Capable -
    4 ohm Capable -
    Center 100 W
    Surround L/R 100 W/Ch
    Surround Back 100 W
    Dynamic Power** -
    3 ohm (Front) 230 W/Ch
    4 ohm (Front) 170 W/Ch
    8 ohm (Front) 115 W/Ch
    Any input would be greatly appreciated. I want so much to love these speakers and serve them justice!
  • Face
    Face Posts: 14,340
    You need an external amp. If your budget is really tight, check out Adcom.
  • danz1906
    danz1906 Posts: 5,144
    janmike wrote: »
    Agreed!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • danz1906
    Thats a good one!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • Face
    Face Posts: 14,340
    Why, he's not using Carver or Flame Linear.
