PSW110 - LFE, or L+R?
NaOH
NaOH Posts: 4
Hey guys, this is a pretty simple question but it's tough to search the forum for "LFE", so here you go:
When hooking up a PSW110, is it better to use the LFE in, or the L and R line-in jacks? I've got an L and R line-out on my AVR. Should I run two cables from one to the other (left and right)?
Post edited by NaOH on
  • vc69
    vc69 Posts: 2,500
    edited November 2009
    It depends on your application.
    If you are using an AVR that does bass management (ie: internal crossover) use the LFE
    If you want to use the crossover in the sub itself, use the L/R inputs.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • NaOH
    NaOH Posts: 4
    Is the crossover in the AVR going to be better? (It's an Onkyo TX-SR607.)
  • BlueFox
    BlueFox Posts: 15,250
    I prefer to run my speakers as large, and no sub, to eliminate any AVR filtering. I use the front pre-out L+R to run the sub, PSW1000. Works great, your results may differ.
