PSW110 - LFE, or L+R?
NaOH
Hey guys, this is a pretty simple question but it's tough to search the forum for "LFE", so here you go:
When hooking up a PSW110, is it better to use the LFE in, or the L and R line-in jacks? I've got an L and R line-out on my AVR. Should I run two cables from one to the other (left and right)?
Post edited by NaOH on
It depends on your application.
If you are using an AVR that does bass management (ie: internal crossover) use the LFE
If you want to use the crossover in the sub itself, use the L/R inputs.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Is the crossover in the AVR going to be better? (It's an Onkyo TX-SR607.)
I prefer to run my speakers as large, and no sub, to eliminate any AVR filtering. I use the front pre-out L+R to run the sub, PSW1000. Works great, your results may differ.Lumin X1 file player, Westminster Labs interconnect cable
