PSW110 - LFE, or L+R?
NaOH
Hey guys, this is a pretty simple question but it's tough to search the forum for "LFE", so here you go:
When hooking up a PSW110, is it better to use the LFE in, or the L and R line-in jacks? I've got an L and R line-out on my AVR. Should I run two cables from one to the other (left and right)?
It depends on your application.
If you are using an AVR that does bass management (ie: internal crossover) use the LFE
If you want to use the crossover in the sub itself, use the L/R inputs.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
Is the crossover in the AVR going to be better? (It's an Onkyo TX-SR607.)
I prefer to run my speakers as large, and no sub, to eliminate any AVR filtering. I use the front pre-out L+R to run the sub, PSW1000. Works great, your results may differ.Lumin X1 file player, Westminster Labs interconnect cable
