5.1 Receiver/Pre for HT use
MrGlobe
MrGlobe Posts: 401
edited November 2009 in Wanted (WTB) Classifieds
I want to get into seperates. As such, I would like a receiver that has pre-outs, an optical input, and enough wattage to drive my center/surrounds. I am also looking for suggestions/options for a cheap 2 channel amp to drive my mains.
Going to drive CS2,70s,60s.
Looking to stay under $400 for both
Globe
Post edited by MrGlobe on
  • vc69
    vc69 Posts: 2,500
    Good Luck.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • MrGlobe
    MrGlobe Posts: 401
    vc69 wrote: »
    Good Luck.
    I'm gonna take that as honest good tidings and not as the pesimistic/sarcastic waste of finger dexterity i'm sure it is.
    Honestly $400 for both the pre and amp would be awesome, I was thinking $250 for receiver (used off a-gon) and then $150 for a 2 channel amp (again, used) I was mainly looking for suggestions on what to look for, and also anything comprable members are looking to sell.
    Globe
  • concealer404
    concealer404 Posts: 7,440
    I'm getting a shipping quote for you this weekend man. :) Might have an amp for you as well. I'll stay in touch. If i have the amp, we can get both there for you and leave enough budget for you to get a remote.
  • vc69
    vc69 Posts: 2,500
    MrGlobe wrote: »
    Globe
    I'm sorry, it really was a genuine sentiment if a little short. My apologies. :o
    I prefer onkyo and used onkyo gear can be had in 4-500 dollar range.
    Edit: As far as pre/pro's go, are you looking for decoding of latest HiRes codecs etc? HK's are popular around here and you could start with a receiver with pre-outs and add amps as you can afford to.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • MrGlobe
    MrGlobe Posts: 401
    I do like my current H/K alot, and would for sure be up for getting a nicer one. It seems like $250 to $300 would net me a nice used receiver.
    This will be my first venture into seperates, so I am excited but have a small budget
  • ben62670
    ben62670 Posts: 15,969
    HK is good, and there is also a Sunfire Pre for sale here if you like the sunfire sound.
    Ben
  • MrGlobe
    MrGlobe Posts: 401
    Haha, unable to comment on a very wide variety of components.
    Never heard much for high-end audio. Even at Best buy or other brick and mortar stores, just never spent the time.
    I could tell you a thing or two about 90's sony receivers, or a handful about low end polk/jbl/yamaha components and speakers :)
  • mrbofus
    mrbofus Posts: 297
    Sorry for sounding dumb, but could someone give me a short explanation of seperates and whats the bennefit?
    thanks,
    Sharp Aqous 40" LCD
    Onkyo TX SR-507 AVR
    Onkyo DX-C390 CD Changer
    POLK RTI8 Mains--Cherry
    the rest...in process...slowly!!
  • KASR
    KASR Posts: 450
    MrGlobe wrote: »
    I definitely recommend an H/K as well - you can get a smoking deal on ebay at the harman kardon store on factory refurbs (latest firmware fixes) check out the 154 and the 254 (for HDMI) Both do not disappoint.
  • MrGlobe
    MrGlobe Posts: 401
    Good Idea, just checked out Harman Kardon's ebay page and there are some good deals there! I like the 254 cause it's 7.1, but my room is only 13'x11' so I don't think I'd really get anything out of it. Also, Its $300 and thats most of my budget.
    Will it affect the surround sound experience to have my front L/R powered by a seperate amp and have my center and surround L/R run off a reciever? It seems like the extra power going to the towers would make the speakers seem mismatched
  • concealer404
    MrGlobe wrote: »
    Nah, the majority of the info comes from the mains anyways.
  • KASR
    KASR Posts: 450
    ^What he said! :D If you hunt for one of the AVR254's on auction through the H/K ebay store, you can usually pick one up for around 200-250, which is a great deal! Especially with the 16-26-3600 series now out.
  • concealer404
    Globe, i've got a lead on an amp for you. I'll update when i hear more. I might be able to take care of both for you in one shot. I think we'll be able to squeek in under $400 after shipping, it'll be close, but i think we can do it.
  • MrGlobe
    MrGlobe Posts: 401
    Woohoo! Thats good news. Let me know whenever you hear something, and thanks a bunch of the help man!
